Re: DDOS network issue - checking - Multigig DDOS
DDOS Followup
Currently there are two targeted IPs still fully null routed for all incoming traffic. One of the two was around 3am Central Daylight Time the recipient of a very large DDOS attack from hundreds of sources. It was a UDP Flood, in and of itself this is not uncommon and has been blocked many times before, but the sheer size of this one simply flooded out switches on multiple levels including some outside of our network or control. Once we were able to find the target IP appropriately, we were able to get just that IP and the other on the server blocked, and filtered out with the help of upstream routers to prevent them from coming in further and causing the issues.
The attack impacted our network as well as some others due to the size of it at the time before filtering took place.
This situation is a bit hard to control fully, but we have some plans in motion to help speed the recovery process should such ever occur again, while we certainly hope it would not, in this age you can never just hope, you must plan for it to happen again.
