DNN Hosting Advice
I want to use DNN's hosting capability to manage client sites. I will be hosting sites that are industry-specific and fall into 2 different industry categories (ie, airplanes or boats). Each industry will have modules specific to their industry and share SQL Server dbases. Therefore, I will have 2 DNN "hosting" sites to accomodate each industry's specific needs. Under the Reseller plan, what is the best setup in this scenario? Should/can I have 2 Service accounts (ie, www.boats.com and www.airplanes.com hosting www.boats1.com, www.boats2.com and www.airplanes1.com, www.airplanes2.com respectively?). Along these lines, are other DNN Hosters doing anything similar and what works best under JODO's Reseller Plan? I currently have a DNN 3 Service Plan for "boats" and want to setup "airplanes" using DNN 4. Thanks for any advice/comments.
We have a number of customers doing this, it works pretty well.
You don't really need to service plans to do this, you could do one in a service plan and in a plan with no billing, or you could do it all in one account for dnn3/4, but I'd recommend using 2 just to keep them in manageable order and a bit more "seperate"
