DNS Resolving Issue
I'm not sure what you mean, your hostname is resolving correctly and the website is working fine on both addresses.
pysance
As I explained the problem to you, the IP for your primary name server was delocated by our datacenter.. that IP is no longer going to our name server. And to make problems worse, you are using a 3rd party DNS provider as your second name server
The solution to this is that you delete your primary name server from E.Manager > Server Aliases and recreate it. You'll get a new IP and use this to update your name server with your registrar
Still nothing but working sites here, including using Google. Of course with problems such as Yash mentioned, it's possible..
it's bodymod.org
EDIT: And I already explained what was causing this. pysance needs to do what i said in order for his site to resolve correctly from all corners of the globe
