Drive Imaging/Backup Software?
Discussion in 'Suggestions and Feedback' started by schooner, Jan 20, 2006.
  1. schooner
    schooner Perch
    What are most here using to do drive images, ie so can do full restores of a drive if there is a failure.
    Looking so far at True Image or Norton Ghost. Not a fan of anything Symantec so leaning towards True Image. Any comments or suggestions?
  2. Yash
    Yash Bass
    True Image Server has worked great for us. Our current backup and restore procedures are based around it
  3. schooner
    schooner Perch
    Thanks. At $700 its a bit much for our needs. We do need to image both client and server but the server is only for testign and dev so jsut need a normal imaging solution for it. True Image standard will not run on Win 2003 server :( Requires server version.
  4. Yash
    Yash Bass
    having tried a few other solutions, True Image is unfortunately the only solution I can recommend to you. If you do find something else, please post it here and I'd be happy to comment on it
  5. Stephen
    Paragon drive image is good, as long as you don't need incremental images.
Share This Page
Plesk Web Hosting
VPS Hosting
H-Sphere Web Hosting
Other Services
