Easy way to move an account from ColdFusion to Unix Cluster?
Hi there, we have a customer that is on the ColdFusion cluster, but has no more future plans for ColdFusion, is there an easy way to move him to the Unix Cluster for now? Thanks!
coldfusion to linux can be done easily by us, but coldfusion to linux cannot be done in the same manner, it will require you to delete the domain and re-add it on linux side.
Got it, I think I need some clarity then on the billing side to save a buck or 2. You charge
Additional ColdFusion Domains $1.00/Domain per Month
Does that apply to anyone running on a ColdFusion server? Or just anyone that has ColdFusion enabled on a ColdFusion server? As these are 2 people on a ColdFusion server but are running little more than Static HTML. Thanks!
