How to force secure connection to remote 2003 server using RDC
Hi!
I edited the terminal services on a remote Windows Server version 2003 SP2.
I set the terminal services to use a SSL certificate at High level.
I can connect using the RDC (Windows 7) client using the domain and the lock occurs on the taskbar at the top. What is not working is I am also able to connect using RDC and just a IP address and no SSL. I want to require the domain being used so that the SSL will have to be used or that https is required when using the IP address to remotely administer the server. Any ideas (please be specific)? Or should add the two default IP addresses to the not granted access list. I still want to be able to access the websites without https. Only remote terminal services should have to be secure.
