Anyone has tried getting FileUpload working on JH Servers (Medium Trust Enviorment) - using ASP.NET - C#
We've tried a whole lot of stuff using Virtual / Physical Path - nothing works.
What's happening - is the moment we are putting a FileUpload Control or Input - with nothing on the page and on button click putting a response.write - that is also causing the issue.
We've even tried ASP.NET Ajax 3.5 Async File Upload control.
PLEASE HELP !!!
Sample of code:
PLEASE HELP !!!
Sample of code:
Code:
<%@ Page Language="C#" AutoEventWireup="true" CodeFile="Testpage.aspx.cs" Inherits="Admin_Backend_Testpage" %>
<%@ Register Assembly="AjaxControlToolkit" Namespace="AjaxControlToolkit" TagPrefix="asp1" %>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head runat="server">
<title></title>
</head>
<body>
<form id="form1" runat="server" enctype="multipart/form-data" method="post">
<%-- <div>
<asp:FileUpload ID="Fileupload1" runat="server" />
<asp:Button ID="Button1" runat="server" onclick="Button1_Click" />
</div>
<div>
<asp:FileUpload ID="Fileupload2" runat="server" />
<asp:Button ID="Button2" runat="server" onclick="Button2_Click" />
</div>
<div>
<input id="Fileupload3" type="file" runat="server" />
<asp:Button ID="Button3" runat="server" onclick="Button3_Click" />
</div>--%>
<div>
<asp:ScriptManager ID="ScriptManager1" runat="server">
</asp:ScriptManager>
<asp1:AsyncFileUpload runat="server" id="AsyncFileUpload1" CompleteBackColor="Lime" UploaderStyle="Modern" ErrorBackColor="Red" ThrobberID="Throbber" >
</asp1:AsyncFileUpload>
</div>
</form>
</body>
</html>
Code:
using System;
using System.Collections.Generic;
using System.Linq;
using System.Web;
using System.Web.UI;
using System.Web.UI.WebControls;
using System.Security.Permissions;
using System.IO;
using System.Drawing.Design;
using System.Drawing;
public partial class Admin_Backend_Testpage : System.Web.UI.Page
//protected void Page_Load(object sender, EventArgs e)
// //string strpath = Request.PhysicalApplicationPath;
// //FileIOPermission perm = new FileIOPermission(FileIOPermissionAccess.Write, strpath);
// ////Fileupload1.SaveAs(Server.MapPath("~/UploadPhotos") + Fileupload1.FileName);
// //perm.Demand();
// //string appPath = Path.Combine(strpath, "/Admin/Backend/UploadPhotos");
// if (!IsPostBack)
//string appPath = Path.Combine(strpath, "/Admin/Backend/UploadPhotos/");
//Response.Write("File 1 will be uploaded to this directory:" + Request.MapPath("~/Admin/Backend/UploadPhotos/"));
//Response.Write("<br/>File 2 will be uploaded to this directory:" + appPath);
//protected void Button1_Click(object sender, EventArgs e)
// Response.Write("hello");
// // string strpath = Server.MapPath("UploadPhotos");
// //perm.Demand();
// //Fileupload1.SaveAs(Server.MapPath("./UploadPhotos/") + Fileupload1.FileName);
// //Response.Write(appPath);
// ////Fileupload1.SaveAs(Server.MapPath("~/UploadPhotos/") + Fileupload1.FileName.ToString());
// //perm.Demand();
// //string appPath = Path.Combine(strpath, "/Admin/Backend/UploadPhotos/");
// Fileupload1.SaveAs(Request.MapPath("~/Admin/Backend/UploadPhotos/") + Fileupload1.FileName.ToString());
//protected void Button2_Click(object sender, EventArgs e)
// string strpath = Request.PhysicalApplicationPath;
// string appPath = Path.Combine(strpath, "/Admin/Backend/UploadPhotos/");
// Fileupload1.SaveAs(appPath + Fileupload2.FileName.ToString());
// Response.Write(appPath);
//protected void Button3_Click(object sender, EventArgs e)
// HttpPostedFile filPostedFile = Fileupload3.PostedFile;
// int intLength = 0;
// byte[] bytUpload = new byte[0];
// // filPostedFile = Fileupload3.PostedFile;
// intLength = filPostedFile.ContentLength;
// if (filPostedFile.ContentLength > 0)
// bytUpload = new byte[intLength];
// filPostedFile.InputStream.Read(bytUpload, 0, intLength);
// WriteToDB(filPostedFile.FileName.ToString(), ref bytUpload);
// else
// Response.Write("ContentLength is zero.");
//private void WriteToDB(String strName, ref byte[] oBuffer)
AsyncFileUpload1.UploadedComplete += new EventHandler<AjaxControlToolkit.AsyncFileUploadEventArgs>(AsyncFileUpload1_UploadedComplete);
AsyncFileUpload1.UploadedFileError += new EventHandler<AjaxControlToolkit.AsyncFileUploadEventArgs>(AsyncFileUpload1_UploadedFileError);
[System.Security.Permissions.PermissionSet(System.Security.Permissions.SecurityAction.Assert, Unrestricted = true)]
protected void AsyncFileUpload1_UploadedComplete(object sender, AjaxControlToolkit.AsyncFileUploadEventArgs e)
string fileloc = @"\UploadPhotos\";
//string fileloc = Path.Combine(strpath, "/Admin/Backend/UploadPhotos/");
System.Threading.Thread.Sleep(5000);
string randomstr;
if (AsyncFileUpload1.HasFile)
//create random filename and test it against server dir for dups
randomstr = RandomString(10, false);
string imagename = randomstr + System.IO.Path.GetExtension(e.filename);
if (System.IO.File.Exists(MapPath(fileloc) + imagename))
//FileIOPermission perm = new FileIOPermission(FileIOPermissionAccess.Write, fileloc + imagename);
// perm.Demand();
// // Create a bitmap of the content of the fileUpload control in memory
// Bitmap originalBMP = new Bitmap(AsyncFileUpload1.FileContent);
//// Calculate the new image dimensions
// int origWidth = originalBMP.Width;
// int origHeight = originalBMP.Height;
// int sngRatio = origWidth / origHeight;
// int newWidth = 100;
// int newHeight = newWidth / sngRatio;
// Create a new bitmap which will hold the previous resized bitmap
//Bitmap newBMP = new Bitmap(originalBMP, newWidth, newHeight); // Create a graphic based on the new bitmap
//Graphics oGraphics = Graphics.FromImage(newBMP);
// Set the properties for the new graphic file
//oGraphics.SmoothingMode = oGraphicsSmoothingMode.AntiAlias;
// oGraphics.InterpolationMode = InterpolationMode.HighQualityBicubic; // Draw the new graphic based on the resized bitmap
// oGraphics.DrawImage(originalBMP, 0, 0, newWidth, newHeight);
// Save the new graphic file to the server
//newBMP.Save(MapPath(fileloc) + imagename);
// // Once finished with the bitmap objects, we deallocate them.
// originalBMP.Dispose();
// newBMP.Dispose();
//oGraphics.Dispose();
// Image1.Visible = true;
// Image1.ImageUrl = @"/useruploads/" + imagename;
AsyncFileUpload1.SaveAs(MapPath(fileloc) + imagename);
//ScriptManager.RegisterClientScriptBlock(this, this.GetType(), "size", "top.$get(\"" + uploadResult.ClientID + "\").innerHTML = 'Uploaded size: " + AsyncFileUpload1.FileBytes.Length.ToString() + "';", true);
void AsyncFileUpload1_UploadedFileError(object sender, AjaxControlToolkit.AsyncFileUploadEventArgs e)
//ScriptManager.RegisterClientScriptBlock(this, this.GetType(), "error", "top.$get(\"" + uploadResult.ClientID + "\").innerHTML = 'Error: " + e.statusMessage + "';", true);
/// <summary>
/// Generates a random string with the given length
/// </summary>
/// <param name="size">Size of the string</param>
/// <param name="lowerCase">If true, generate lowercase string</param>
/// <returns>Random string</returns>
private string RandomString(int size, bool lowerCase)
System.Text.StringBuilder builder = new System.Text.StringBuilder();
Random random = new Random();
char ch;
for (int i = 0; i < size; i++)
ch = Convert.ToChar(Convert.ToInt32(Math.Floor(26 * random.NextDouble() + 65)));
builder.Append(ch);
if (lowerCase)
return builder.ToString().ToLower();
return builder.ToString();
