CLuster2:
If you HAVE in string 64.71.228.8 please change to - 173.0.138.12
If you HAVE 64.71.229.11 change to 173.0.138.16
if you have 66.232.25.15 change to 173.0.139.236
As an alternative, use the mssql1/2/3 dns name listed in your control panel as it will map to the correct IP properly automatically.
If you have the old IP in, it will work for a short time more, but it will be much slower.
note:
This only applies for web servers connecting to SQL servers. you cannot connect directly to SQL servers from outside the web servers at this time. We will apply a work around for that soon.
This si so far a very common thread/complaint seen today, so this is a self help fix as well.
note:
