nns and ns2 accounts after Aug 2005
In the emanager for the DNS names, listed are:
ns.mydomain.com
ns2.mydomain.com
ns3.mydomain.com
ns4.mydomain.com
The documentation says to use ns3 and ns4 for accounts created after Aug 2005. What I would like to know is can ns and ns2 be used as well?
Tony
They are there for future use. You can ignore them for now, but better if you create child nameservers for them right now( not mandatory).
Thanks for the prompt reply. I know this isn't a Jodo issue, but I'm having problems with my DNS registrar where I can only get ns and ns2 to show up. I get errors when I enter ns3 and ns4. However, when I ping ns3 and ns4 they resolve properly (as do ns and ns2). So since I can only "see" ns and ns2 in my DNS registrar, I was wondering if it would be fine to use them instead of ns3 and ns4.
Thanks again
Tony
no you can not use ns and ns2 instead as they do not contain the data for the domains since then.
