Order by clause in MSSQL
kmar
Guppy
Hello,
I just had my database converted from Access to MSSQL, but now I run into a problem. MSSQL doesnt seem to be able to order by text. I really need to be able to do this. I used this clause with access:
SQL = "select * from members where status = 2 ORDER BY username asc;
How can I get this working in MSSQL?
Please hlp me!
Thanks!
You can not perform an ORDER BY on a text, ntext, or image field (those fields are actually pointers). From the context of your query, though, I'm guessing you probably don't need the "username" field to be a MSSQL text field; change that field to a varchar(x) field and you'll be fine. Text fields have different meanings in Access and MSSQL; in the former text fields refer to pretty much any field containing text, while in the latter they refer to *large* fields containing text.
