Packetlosses due to DDOS incoming
Stephen
US Operations
Staff member
We are aware there is some packetloss on the network, there is an incoming DDOS attack we are working to check it out now.
Packtloss is not o bad now, pings are howing a bit higher than normal but getting through properly.
One link is still seeing major DDOS attacks the primary InterNAP link is mostly mitigated. Overall depending on route you may see a little packetloss, but it should work properly.
