The following is required by the phpMyDirectory script:
1./ Your host needs to support ioncube run-time loading or have it installed. (more information at ioncube.com).
2./ PHP GD2 library (widely used) is required to process jpeg images for "products and services" and "image gallery" thumbnails, security code on the submit page is also generated using GD2.
3./ Please, make sure you can use the CHMOD command.
4./ To run the scripts you need a PHP version 4.1.2 +.
5./ To run the script you need mySQL 3.23.23 +. Sure, you need an account and your own database created to start working. phpMyDirectory can share an existing database with any other script. (NOTE: mySQL 4.0.0 + is required for the one line search function - but is not necessary for the rest of the software)
From the forums, I believe 3-5 are supported. Are the first two?
Also,
"Apache webserver with mod_rewrite module enabled is required to rewrite the URLs to create search engine friendly pages."
Is this enabled?
KL
Also,
Is this enabled?
KL
