Dear Sirs,
Thanks for creating the sample Plan for my first customer
I have some questions:
Thanks in advance
- I want that my plan have unlimited Domain Aliases and unlimited Mail Domain Aliases, how should I do this? leave the max field empty or how?
- I am a bit confused about the difference between "MS SQL Database User" and "MS SQL Login". What's the difference? This confusion is emphasized by the fact that you have configured MSSQL with 1 database & no DB user, but mysql is configured with 0 databases and 1 mysql user
- What's the difference between "Credit limit" (whose value is 5 in the plan you created), but the monthly cost of the actual account was set to 6.95. What's the difference?
- In the second step of the plan wizard, I can set the amount that the customer is going to pay if he exceeds his quota- However, I do not want that he exceed his quota, How can I do this? leaving the field as blank?
- Also in the second step there is a section called "quota". In that section there is a textbox for the "monthly" cost and the extra cost per unit. What is the exact difference between the two values? I do not want that the users exceed its resources since they are going to pay me by check
- Is it possible to rename a Plan? If so, how?
- Where can I find more information about this text that appear in the "access" section of the CP: "If no boxes are checked, full access to this plan is granted"
Thanks in advance
