questions
Q
qwerty22
Guest
Hello,
I have been looking two of your hosting plans (WinVPS Silver and Semi Dedicated I). I have website that gets around 30.000 visitors per day and is using about 60 gigs per month. This means the web is hitting 40.000 to 50.000 times a 6 MB MSSQL database with a very simple query. In one of the threads I found
http://support.jodohost.com/vps-plesk/7675-vps-vs-semi-dedicated-offerings.html
one of the administrators "Yash" says "Semi-dedicated requires zero admin knowledge, and you are on dedicated mssql servers. On VPS, the external database services are offered from our standard cluster"
So my question is: which of the two plans gives the best performance database-wise??
Thank you
