System.Security.Permissions.ReflectionPermission
Discussion in 'Microsoft Development' started by olley, Sep 20, 2011.
  1. olley
    olley Guppy
    Is there a chance to get System.Security.Permissions.ReflectionPermission allowed for .NET 4.0?
    I am getting an error when I try using standard .NET classes for JSON serialization.
    Here is the stack trace:
    Exception Details: System.Security.SecurityException: Request for the permission of type 'System.Security.Permissions.ReflectionPermission, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089' failed.
    Code:
    [SecurityException: Request for the permission of type 'System.Security.Permissions.ReflectionPermission, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089' failed.]
       System.Security.CodeAccessSecurityEngine.Check(Object demand, StackCrawlMark& stackMark, Boolean isPermSet) +0
       System.Security.CodeAccessSecurityEngine.Check(CodeAccessPermission cap, StackCrawlMark& stackMark) +31
       System.Security.CodeAccessPermission.Demand() +46
       System.Reflection.Emit.DynamicMethod.PerformSecurityCheck(Module m, StackCrawlMark& stackMark, Boolean skipVisibility) +248
       System.Reflection.Emit.DynamicMethod..ctor(String name, Type returnType, Type[] parameterTypes, Module m, Boolean skipVisibility) +49
       System.Runtime.Serialization.Json.CriticalHelper.BeginMethod(CodeGenerator ilg, String methodName, Type delegateType, Boolean allowPrivateMemberAccess) +162
       System.Runtime.Serialization.Json.CriticalHelper.GenerateClassWriter(ClassDataContract classContract) +144
    If I am not mistaken, JodoHost has this permission granted for .NET 2.0 (see http://support.jodohost.com/showthread.php?t=7974&highlight=ReflectionPermission topic). May be it is time to add it to the list of granted permissions for .NET 4.0 too?
  2. Stephen
    We do allow certain reflection, I am checking this out.
  3. olley
    olley Guppy
    Here is a simple ASPX page for testing.
    Code:
    <%@ Page Language="C#" %>
    <%@ Import Namespace="System.IO" %>
    <%@ Import Namespace="System.Runtime.Serialization.Json" %>
    <%@ Import Namespace="System.Runtime.Serialization" %>
    <script runat="server">
        [DataContract]
        class Foo
            [DataMember]
            public bool bar = true;
        class Tester
            public static string DoStuff()
                DataContractJsonSerializer serializer = new DataContractJsonSerializer(typeof(Foo));
                MemoryStream memStream = new MemoryStream();
                Foo foo = new Foo();
                serializer.WriteObject(memStream, foo); // Fails on this line
                memStream.Position = 0;
                StreamReader reader = new StreamReader(memStream);
                return reader.ReadToEnd();
    </script>
    <html>
     <% Response.Write( Tester.DoStuff()); %>
    </html>
    On my local machine it outputs the JASON representation of the the Foo object: {"bar":true}
    On the hosted site it throws the above mentioned exception.
  4. olley
    olley Guppy
    I am on win15 (Windows Server 2003) if that matters.
  5. olley
    olley Guppy
    Um... Any thoughts on that? Will you add this permission?
  6. Stephen
    still checking it, wasnt in a lot on software side due to some other plans (prep to take dc pics)
  7. olley
    olley Guppy
    Thank you, I really appreciate that.
  8. Stephen
    Check it now and see if any error, I've allowed an additional reflection permission.
  9. olley
    olley Guppy
    Same error if I try the sample page provided above :(
  10. Stephen
    On reflection, we really can't allow it in full, I have allowed ReflectionEmit and RestrictedMemberAccess (for LINQ functions)
    I tried to find which exactly JSON was using, but wasn't able, do you know?
    Looks like it is wanting PrivateMemberAccess...
  11. olley
    olley Guppy
    Yes, LINQ works for me, I can confirm that. Don't know about JSON error besides what I see in that exception info though...
Share This Page
Plesk Web Hosting
VPS Hosting
H-Sphere Web Hosting
Other Services
