What is SQL Azure?
liming
Perch
So i've been reading posts where you can host your database on sql azure.
For the life of me, I can't figure out what is Azure? I mean it seems to me that it's just a hosted version of sql server?
Completely confusing, anybody can tell me how is it any different than a hosted version of sql server?
It's pretty much acts and behaves like SQL Server 2008, from all I have read. We are evaluating setting up SQL Server 2008 as well.
Thanks! I'm beginning to see the concept of it, but I guess I need to research more on the specifics.
And don't worry, we stick with you guys for the great support :)
I must chip in and say that Azure is a pretty awesome platform if you are a .net developer looking for a scaleable solution, but I don't it will replace you guys (jodo) in a hurry. Given the value/flexibility you offer I wouldn't worry :)
I have searched it out a bit, it is interesting they basically are putting a sql 2008 server out there as a huge hosted service. it has some special .net calls for some unique parameters, but nothing major diff than 2008.
