I had not needed to reboot or even IIS reset for the others, maybe oracle does need this, but I don’t see why it could be different, Initially I did not have the “System.Data.OracleClient.OraclePermission” I just had System.Data.Oracle.OraclePermission, but now it is correct.
Try now, and if is does not work, please send me a PM with a link so I can test without having the delay of the forums here.
The security exception is gone but there’s a new one
“System.Exception: System.Data.OracleClient requires Oracle client software version 8.1.7 or greater.”
My mistake. Apparently, there needs to be some software installed on jodohost’s servers from oracle. I thought it would all be in the .net framework.
Found something on this:
http://dotnetjunkies.com/WebLog/rtgurskevik/archive/2005/01/19/45958.aspx
Apparently it is not a software installation problem, it is an oracle user authentication/permissions problem – perculiar to oracle installations on windows
In case you missed the pm I sent you
New error
ORA-12541: TNS:no listener
From OraFAQ Forum: Networking and Gateways » Another ORA-12541 TNS:no listener question it seems it is a firewall or permissions problem or something like that – ie, some extra software on the box that is interfering with oracle’s running on windows.
Got PM, sending the right direction to see what the problem is here.
Has this been resolved? I have a customer with a problem connecting.
