ASP.Net 3.5
I believe my site is running on Win21. I noticed my ASPNET version was set to v1.1 instead of v2.0, so I just changed it. Will this give me the ASP.NET 3.5 support? I’m looking to port a .NET 2.0 desktop project to an ASP.NET 3.5 project.
At this moment it is not there. It is planned to made available in near future. If you are a reseller, you can create a new account and that will give you asp.net 3.5 server right away.
I’m not a reseller, just a regular customer. It may be a couple weeks before I get this project started, so I’m just hoping it comes soon :slight_smile:
Hi. I’m on Win14, has this been upgraded to .Net 3.5 yet?
Win14 is having ASP.Net 3.5.
Can you give us an update on if/when MVC will be supported?
Joel
Should be soon, I’d hoped to already have it installed by now as it is released, but I’ve have some behind the scene delays and I need to be on hand if any issue should happen during the installation and rollout of at least the first few.
Excellent, I can hardly wait to start using it.
Now, I did create a new Windows account prior to this post just to check the computer that account landed on (Win29 I believe). But is there a better way to find out what servers have what? And to make sure I can create an account in the right place?
Joel
Win29/30 and 31(not on the system just yet) will be having it first.
It will be rolled out to all except Win13 over the next 2 weeks.
Win29/30 now having MVC, others coming along now on both clusters.
I think most have probably followed the maintenance threads but just in case it was missed, as of tonight win20+ have MVC and all of cluster2 have MVC support.
Win14+ now outfitted with MVC support.
Are Win 28 and 29 IIS6?
Are there any plans for running an IIS7 server available to resellers?
thanks,
.b
Every server is running IIS6, we do not have any windows 2000 and a for IIS7, windows 2008 is NOT and is not in development for Hsphere, so no IIS7 :frowning:
Ok, thanks.
:frowning: Parallels is doing awfully little to keep the product even remotely up to date. It still doesn’t even officially support MS SQL Server 2005 according to the website..
You are right, the situation looks like they want to force everyone to the lesser Plesk product.
