CDOSYS itself is generating a SPAM error!
Tanmaya, could you know if you do remove the offending rules - I think a few of us have turned spam checking off or very low to get around it.
So it would be good to return to normal checking level if possible.
Cheers!
Customer can’t be a pain. Can they be? :slight_smile:
A few others will still let us know. They say “we won’t do anything. fix it!!” :slight_smile:
You mean spamassassin state before the rules were added?
Note everyone, this is now in writing! Bookmark this post for later referral. :slight_smile:
Heh, tell em to post here, it’s nice to be reminded how polite we are. And oops I meant to say, “let us know” if you remove the rules…
…yep, so we can return it to “normal” instead of “relaxed” and restore spam checking on certain accounts that needed it removed to get around the CDO script error.
One needs to keep himself positive to keep going :slight_smile:
It does help when people are polite and keep their calm throughout the issue.
Disabled these rules, should be good enough for you:
CTYPE_001C_A
FH_MSGID_01C67
DYN_RDNS_SHORT_HELO_HTML
MPART_ALT_DIFF
FH_HOST_ALMOST_IP
Brilliant Tanmaya, thanks. FH_MSGID_01C67 was the big culprit for me.
Even after disabling all spam rules that I can find and removing spam for the sending account I am still getting this error. I have submitted a ticket (NRT-23995-311), but this has been dragging out for two days now without a resolution.
Any ideas? I’m stuck. This was never a problem until recently (assuming HSphere updates).
.brit
As I said there, this error is not possible unless is delivered to some local user.
Are you sure the error message is exactly the same yet?
Yes, I am sure the error message is the same.
The client does not work on Sunday. I will update with more info on Monday.
