I’ll double check, but I have the session timeout variable set to 20 minutes, and this happens in much less time than that. Also I would get an error or something, wouldn’t I. Not just a blank page?
This blank page also happens on phillipslanes.com, where there are no session variables.
This Is Absolutely Crazy! Myclientpro.com Cannot Even Be Used Today. You Click On The Page, It Loads, Click On Another Page And Get A Blank Screen That Says Done!
Manish and I are checking with you and seems to be great, servers are scared of me, when I try to find a problem it doesnt come up, when I step away it blows up…
As for the login issue, I found only clicking on the admin functions forces a logout, otherwise I have been online logged in since, testing it for you alongside Manish.
Page loads fine here, though admittedly the first page load was somewhat slow (paused for a couple of seconds). Refreshed a bunch of times without problems either. I’m not saying the problem is non-existant, but at least for the time being it’s OK.
Incidentally, Are You In Love With Your Shift Key?
