Email problems
Great to know that it works for you!!
This is not a permanent solution, but is not going to be change soon for some reason.
Again, this makes it sound strange why is the actual IP still not working for you.
Just out of curiosity.. what type of cablemodem is it? DOCSIS/EuroDOCSIS or something else?
It’s DOCSIS. It’s a Linksys.
All,
I just wanted to post an update. On 6/24/05 Jodo added an additional IP to their mail server. I had no problems connecting to that server. Because of this two things happened. One I was once again able to access my e-mail, but more importantly, I went back to my ISP and told them that the problem was most likely in their network.
After a lot of team work between Jodo and my ISP, I am happy to say that I am now able to connect to the Jodo mail server on the original IP address. It would seem that there was a “configuration” problem on my ISP’s network.
Thank you Jodo for all your support. I will, and already have, suggested to others to use you service!!
Thank you
Bryan
