Help with VPS
You are right.. we are checking this out
Hey Yash. Same issue here. I recreated the account and was issued an IP pretty close to the first one. I cannot connect to the new IP. I can however connect to the old IP.
We are working on this Code Cleric. I promise a resolution today
Thanks Yash
Ok an update. We’ll have this fixed by noon (15 hours from now).
We are going to be doing a fresh VPS and OS install if needed as well..
Sounds like it’s been rough. I wish you the best of luck, as I am scheduled to give this account to my client in one hour 8o . Just checking in, don’t mean to be riding you about this, but wanna see how it’s coming. Thanks Yash
its 2005 now :slight_smile: seems like the problem is still not solved :frowning:
I have opened a ticket about it, hope you will fix it soon…
There is an issue with the networking, being that it is a holiday, the typical unix staff is not on hand to address this matter, it will be addressed when one is available.
issue is fixed, thanks,
and happy holiday (hallowen right?)
no, it was Diwali, but also happened to be halloween as well, but Halloween is not too important in the scheme of things :smiley:
