Hsphere update
Win7 is fully online now on hsphere.
Hsphere update
Re: Hsphere update
Now trying again on win16, possible a few iisresets in the next 20 minutes.
Re: Hsphere update
Wincf and wincf3 will be online fully in about 20 minutes or less.
Win16 got to the final part of the install before failing and has been sent over to Parallels, I think it too will be online soon.
Re: Hsphere update
working on win17 now as well, it may have a few iisresets
Re: Hsphere update
Wincf2 completed mostly successful but Parallels is working on it to fix one minor issue in coldfusion control.
Re: Hsphere update
Wincf3 is online and working fully with hpshere now.
Re: Hsphere update
WinCF2 can now properly control CF and fully online, wincf will be online and ready within 5 minutes.
Re: Hsphere update
win21 may iisreset a few times in the next 30 min.
Re: Hsphere update
WinCF is now online fully with Hsphere.
Re: Hsphere update
Win17 is runing final packages install, the problematic packages are done.
Win21 is running still, win23 is started, and win16 is also being worked on.
Win2 will be checked and hopefully resolved before noon.
Re: Hsphere update
Win17 is almost done IIS just reset final time for hpshere.
Win16 installs going on final packages it too will iisreset in coming 30 min.
Win23, i being looked at by developers having a permissions error on registry due to initial trouble with support at parallels.
Win2 I am working to fix now, since they have given a script patch.
Re: Hsphere update
win17 done.
Re: Hsphere update
Win21 is completed and working with hsphere.
Re: Hsphere update
Win23 is being worked on by developers right now. They are fixing some registry keys, much as I expected would be needed.
Win16 is taking longer than anyone had hoped, having an odd error.
Re: Hsphere update
Win16 is fully online now.
Win23 and Win2 actively being worked on and may have some further iis restarts.
Re: Hsphere update
Win23 COMPLETED. Win2 is finishing up final packages
Re: Hsphere update
All servers are completed now.
I am going to hold off an calling it fully done until we have checked servers out a bit, but 99% done now for sure.
Re: Hsphere update
SiteStudio is now resolved.
Win16 server is still experiencing some failures even though it thinks all services ready to go.
Mail DNS errors may still be an issue on some as well.
Re: Hsphere update
Win16 now FIXED. All servers are now working properly.
The only remaining issue now is mail DNS bug which is also being worked on.
there are a few smaller issues possibly with webshell not working which we will be checking and resolving if seen.
We are fixing an error in webshell on a server by server basis where it says can’t access / permissions denied, or gives a win32api error.
Fixed servers: all but win21/24/wincf/wincf2 and they are working partially, will be completed by noon or before.
Will add others as completed.
