Hsphere upgrade to 3.2 patch1 - Starting Thursday, February 26, 2009 at 10:30 EST
CF1 Update has started.
CF1 is done. About to go and update CF2.
CF2 is done. Clsuter2 Update has been done.
If you have any issue, kindly send us ticket. We will check it.
Hello,
We’ve been notified by clients that there is some issue logging into the Cerberus helpdesk since the updates, if you are unable to login we ask you to send a ticket via email for the meantime:
Help & Knowledge Base - OPSPI Quick Start Guides | JodoHost
Helpdesk logins should be working now.
ok another update, win3 and win5 are having a lot of FTP users getting errors like:
Response: 530 User username cannot log in, home directory inaccessible.
We are working on this trying to find the culprit and the fix in the most timely manner.
I have checked and confirmed that sites for these users ARE working, just FTP cannot login.
Win3 fixed, going to fix Win5 now.
Win5 fixed now.
Win1 webshell is having problems working giving a directory permissions error even though all permissions are indeed set properly.
I have spent quite a while looking into the matter and haven’t given up, but will soon be moving on to the cluster1 update, FTP and other functions are working properly it is only webshell giving errors, and we will get it fixed as soon as possible.
