WinCF4 is completed now.
WinCF3 sites are asking for password at this time, we are trying to get this fixed at top priority since the package rollback on one install fail made such an impact.
Edit:
just some sites, seems maybe just php again, checking further now.
confirmed it was just php based sites giving a pass prompt.
And it is resolved. Hsphere is NOT connected to wincf3 yet, but sites are not down due to it now anyway.
Wincf2 requires a reboot before we can do anything else on it, so before it gets anymore into day going to proceed with that. After this is anything needs a reboot I will attempt to wait until after 8pm across the US.
MSSQL7 and 8 are both done.
MSSQL3/4/5 all done.
There are a several MSSQL servers(MSSQL1/2 and 6) that are not connected to CP yet.
There are a handful of of windows web servers (Win7,Win17, Win21/23/24)
And CF servers wincf1 and wincf3
We are working with Parallels to resolve complex fails in the installation of the new software on all of these, services are UP on them, if you need assistance let us know via ticket and we will do our best to help you.
Adding domains and CP management is not possible with these servers at this time, we will update as that situation changes.
We are still awaiting some results from Parallels checking, they’ve checked into these issues and working on fixes.
MSSQL1 is now linked to the CP server.
MSSQL2 is now linked as well.
We’ve learned that some servers are not installing SSL certificates since the upgrade, via control panel, we are checking into this now.
We are still awaiting updates on SSL matters and the few remaining servers unable to link.
I have escalated all tickets as no updates recently from Parallels.
SSL install issue is fixed on win28 and we have fix for any other server seeing this matter, we are proactively deploying it over this shift, if you are installing SSL and get this error before we get the fix in raise a ticket and we will do it.
Win23 has all the new packages just one ‘minor’ issue in that it has a blocked the control panel server from communications due to ‘too many invalid attempts’
Working with Parallels on resetting that block now and then we should be set!
Win17 is about 90% up now, php, asp.net, web stats, and general settings should all work there is a known issue right now setting up PERL only, otherwise in the clear on Win17.
Parallels has finally been giving us more regular updates and this issue is with developers on remaining servers now, no one of the issues is the same so it is not a one fix for all waiting.
Win23, NOW WORKING!
After working from update till 9pm last night (about 6 hours ago) Win32 is now giving some off errors and not communicating to the CP, we have put in a ticket regard it now as well.
in the meantime win33 has been enabled for signup temporarily.
Win23 and Win17 are both totally online, Win32 has the issue crop up and not yet resolved, win24/wincf3/wincf/mssql6 are still having issues, I have re-escalated ticket with Parallels.
