my customers need an spanish interface .
This is not posible to use only this interface . I need some spanish webmail, and now more because squirremail can not be used by my customers (Customers don’t know IP address)
I’m already looking for a solution to IP selection thing as said earlier. Please be patient and we should have it solved soon for Squirrelmail.
A little bump. I was just wondering what the situation was with the DWmail security image verification code. All comments so far have been negative and requested removal. I and several others have to agree also.
Cheers
ok, I’ll have it removed with the next upgrade.
Done.
Ahh, much better, Thanks Tanmaya!!. Great Support!!
I really like the DW interface better than Horde. There is one feature that Horde had that I wish DW had. You could select a message, hold down shift, and select another message further down the screen and all the messages in between would be selected. It made mass selections / deletions very easy. Could someone check if this feature is available and could be enabled on DW?
techfuzz
I agree. Much, MUCH better now. A big thanks.![]()
is it posible to tranlate it to different language than english? I need it in spanish . If it is posible I can do for you
DWmail Administrator’s Manual - Version 4.0
Section -
Multi-language capabilities
here look for “Creating your own language packs”
Please, could you give the url to this section? I couldn’t find it
oh sorry. Click on templates in left pane. Scroll down until you see “Multi-language capabilities”.
