Mental Merlin,
We will solve this issue at whatever cost, so take it easy and give us some time here ![]()
Mental Merlin,
man I dono, I just wish this would go away!
Makes the page look bad when im trying to advertise it and it dont work! ?(
is everyone getting this error using a dsn-less connection?
We are monitoring every single ADO error occuring at the moment on WIN7, we are hoping to solve this soon
Also, could everyone here reporting this issue tell me if they are using a DSN less or dsn connection
All the complaints ive checked so far are using a dsn-less connection
The problem has not occured even once now in the last several hours. We made several changes to both mssql3 and win7 as well as disabled a site that we felt was clogging up the outgoing connection queue.
Things look good now. We have a took that monitors every single error thrown up by ADO so we see alot of bad code as well ![]()
i used dsn connection before it was even worse. dsn less connection works better.
thanks
Not even a single DSN connection has errored out for all this monitoring time
The error is reoccuring at 1 hr intervals now, 4 or 5 times it seems
I request all customers experiencing this to try
#1: Use Server IP instead of host name: 64.156.222.125
If that doesn’t work, try
#2: Use a DSN connection
All the errors till now have also used the host name
We plan to contact MS support as well. This seems to be an undocumented Win2003 issue
I have been using “64.156.222.125” since the begining, and it was happening.
As of so far, 9:07 am, from last night it has not happened yet.
OK, couple of more suggestions to people facing this issue:
Specify -
Dataconnection.ConnectionTimeout = 300
Dataconnection.CommandTimeout = 300
OR
use this as your connection string:
Set Dataconnection = Server.Createobject (“ADODB.Connection”)
Dataconnection.open “DRIVER={SQL Server};SERVER=sourcename;DATABASE=dat
abasename;UID=userid;PWD=password”
This should solve the issue, if not
Specify the network library:
“Provider=sqloledb; Network Library=DBMSSOCN; …”
If customers continue to experience this issue after these suggestions, please report
This seems as a serious Win2003 issue. mcse.ms
We will be contacting MS support as well
I haven’t experienced the problem yet today, but it is running slow, should i still do the suggestions?
Not until you experience the issue
Reason its running slightly slow is because all ADO connections are being monitored by a software.
Ok, well let me know how my ado’s are doing, ill fix any. Im server name codyopb_admin and db name codyopb_ohiopbxdb0
Am willing to help.
It has been almost 4 hours since the last errors, but another small batch just came through, we are still on this, you are not forgotten.
I just added:
and it seems to be running faster and no problems yet
Did you have any errors while making that change? Because Out of the 8 errors I saw 7 were for your DB, it might have just been the change taking effect…
[QUOTE=Stephen]
i was having problems at first setting it up, yes, and my friend timed out before i implemented it. but it has been good for the past 15 or so minutes.
I have seen no valid SQL connection errors since my last post stating the fact there were errors.
I am planning to uninstall the monitoring software to speed the sites back up(as it uses a lot of CPU, but worth it to ID problems).
The uninstall will be at 1am Eastern, and will require a reboot.
Turns out the backup is running right now, I had forgotten about that as I am not typically on at this hour. I will get to the uninstall ASAP and not during peak hours of the day.
[QUOTE=Stephen]
thank u guys. great job…
