Actually MX is only incoming, I thought you meant to make an A record.
For MX you only need the mail.*****.com
Sorry about that confusion SMTP does not need an MX record
OK, so I have to make a custom A Record for SMTP then or, should I just keep the MX record for incoming and delete the smtp record?
Has the clients ISP Mail Server been setup to receive mail from their JH domain.com address? It has to be set up so it can create and route email to the proper mailboxes.
I still have a feeling that you have only dealt with this on the JH end and not the client ISP end.
I will try that and see how it works. However, there is no reference of SMTP currently shown under the CNAME area. There is just one that references mail5.mydomain.com. But, I’ll go ahead and add the ones you suggest. Thanks.
Penhall,
Before I made any changes on the JH side, I called my client and had him contact his ISP. I told them to go ahead and setup their end. They had finished doing that about an hour ago. So, I think we are on track now.
you don’t see any smtp.theirdomain.com because Hsphere doesn’t support it as a hsphere controlled config, but it DOES work for making a CNAME and custom MX.
I would probably suggest that the client just uses their ISP smtp server address anyway, possibly avoid some authenticaion/port blocking issues.
Again, sorry on the misreading of the previous email - I’m always leary of letting clients deal with techy stuff and would rather go techy-to-techy when possible.
Got ya! I will be attempting that in just a bit. I just want to make sure that I place the correct “name” in there for each one. I know what the actual addresses are, but I want to make sure that the $ORIGIN is correct when I am done.
Cheers Cap’n
No problem Penhall. This has been a long and confusing thread. I’m even more confused than you are!
I agree about not letting clients deal with the techy stuff. That’s why we set things up for them instead of giving them their own CP’s. I’m the host and I can’t even figure things out correctly! LOL! If they had control of everything - “Oh my God” - my life would really be a zoo!
I rarely give my clients control panel access either — a monkey with matches in a room full of dynamite! (My reselling is usual as a value-add to other work that I do with the client)
I did make two minor changes since I posted this. On the MX record, I removed the “mailsite” name and left it blank because it automatically defaults to the base Domain.
And secondly, on the CNAME section, I tried to make the “NAME” > “mail.clientDomain.com”, but it won’t let me. I think the reason it won’t is because I have yet to turn-off the mail service and it thinks I am duplicating the default address. Once I shut off the mail service after propagation, it should allow me to change that. I think???
