test your medium trust config
web.config and trust config for asp.net 4.0 on 2003:
<?xml version="1.0" encoding="utf-8"?>
<!-- the root web configuration file -->
<configuration>
        Using a location directive with a missing path attribute
        scopes the configuration to the entire machine.  If used in
        conjunction with allowOverride="false", it can be used to
        prevent configuration from being altered on the machine
        Administrators that want to restrict permissions granted to
        web applications should change the default Trust level and ensure
        that overrides are not allowed
    <location allowOverride="false">
        <system.web>
            <securityPolicy>
                <trustLevel name="Full" policyFile="internal" />
                <trustLevel name="High" policyFile="web_hightrust.config" />
                <trustLevel name="Medium" policyFile="web_mediumtrust.config" />
                <trustLevel name="Low"  policyFile="web_lowtrust.config" />
                <trustLevel name="Minimal" policyFile="web_minimaltrust.config" />
            </securityPolicy>
            <trust level="Medium" originUrl="" />
            <fullTrustAssemblies>
                <add
                    assemblyName="Microsoft.VisualStudio.Enterprise.AspNetHelper"
                    version="10.0.0.0"
                    publicKey="002400000480000094000000060200000024000052534131000400000100010007D1FA57C4AED9F0A32E84AA0FAEFD0DE9E8FD6AEC8F87FB03766C834C99921EB23BE79AD9D5DCC1DD9AD236132102900B723CF980957FC4E177108FC607774F29E8320E92EA05ECE4E821C0A5EFE8F1645C4C0C93C1AB99285D622CAA652C1DFAD63D745D6F2DE5F17E5EAF0FC4963D261C8A12436518206DC093344D5AD293"
                <add
                    assemblyName="Microsoft.VisualStudio.Web"
                    version="10.0.0.0"
                <add
                    assemblyName="Microsoft.Web.Infrastructure"
                    version="1.0.0.0"
                    publicKey="0024000004800000940000000602000000240000525341310004000001000100B5FC90E7027F67871E773A8FDE8938C81DD402BA65B9201D60593E96C492651E889CC13F1415EBB53FAC1131AE0BD333C5EE6021672D9718EA31A8AEBD0DA0072F25D87DBA6FC90FFD598ED4DA35E44C398C454307E8E33B8426143DAEC9F596836F97C8F74750E5975C64E2189F45DEF46B2A2B1247ADC3652BF5C308055DA9"
                <add
                    assemblyName="System.Data.SqlServerCe"
                    version="4.0.0.0"
                    publicKey="0024000004800000940000000602000000240000525341310004000001000100272736ad6e5f9586bac2d531eabc3acc666c2f8ec879fa94f8f7b0327d2ff2ed523448f83c3d5c5dd2dfc7bc99c5286b2c125117bf5cbe242b9d41750732b2bdffe649c6efb8e5526d526fdd130095ecdb7bf210809c6cdad8824faa9ac0310ac3cba2aa0523567b2dfa7fe250b30facbd62d4ec99b94ac47c7d3b28f1f6e4c8"
            </fullTrustAssemblies>
            <partialTrustVisibleAssemblies />
        </system.web>
    </location>
    <system.codedom>
        <compilers>
            <compiler language="c#;cs;csharp" extension=".cs" warningLevel="4" type="Microsoft.CSharp.CSharpCodeProvider, System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
                <providerOption name="CompilerVersion" value="v4.0"/>
                <providerOption name="WarnAsError" value="false"/>
            </compiler>
            <compiler language="vb;vbs;visualbasic;vbscript" extension=".vb" warningLevel="4" type="Microsoft.VisualBasic.VBCodeProvider, System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
                <providerOption name="OptionInfer" value="true"/>
            </compiler>
        </compilers>
    </system.codedom>
    <system.net>
        <defaultProxy>
            <proxy usesystemdefault="true" />
        </defaultProxy>
    </system.net>
    <system.web>
        <authorization>
            <allow users="*" />
        </authorization>
        <browserCaps userAgentCacheKeyLength="64">
            <result type="System.Web.Mobile.MobileCapabilities, System.Web.Mobile, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
        </browserCaps>
        <clientTarget>
            <add alias="uplevel" userAgent="Mozilla/5.0 (compatible; MSIE 6.0; Windows NT 5.1)" />
            <add alias="downlevel" userAgent="Generic Downlevel" />
        </clientTarget>
        <compilation>
            <assemblies>
                <add assembly="mscorlib" />
                <add assembly="Microsoft.CSharp, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
                <add assembly="System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
                <add assembly="System.Configuration, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
                <add assembly="System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
                <add assembly="System.Data, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
                <add assembly="System.Web.Services, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
                <add assembly="System.Xml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
                <add assembly="System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
                <add assembly="System.EnterpriseServices, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
                <add assembly="System.IdentityModel, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
                <add assembly="System.Runtime.Serialization, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
                <add assembly="System.ServiceModel, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
                <add assembly="System.ServiceModel.Activation, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"/>
                <add assembly="System.ServiceModel.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"/>
                <add assembly="System.Activities, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"/>
                <add assembly="System.ServiceModel.Activities, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"/>
                <add assembly="System.WorkflowServices, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"/>
                <add assembly="System.Core, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
                <add assembly="System.Web.Extensions, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" />
                <add assembly="System.Data.DataSetExtensions, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
                <add assembly="System.Xml.Linq, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
                <add assembly="System.ComponentModel.DataAnnotations, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"/>
                <add assembly="System.Web.DynamicData, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"/>
                <add assembly="System.Web.ApplicationServices, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" />
                <add assembly="*" />
            </assemblies>
            <buildProviders>
                <add extension=".aspx" type="System.Web.Compilation.PageBuildProvider" />
                <add extension=".ascx" type="System.Web.Compilation.UserControlBuildProvider" />
                <add extension=".master" type="System.Web.Compilation.MasterPageBuildProvider" />
                <add extension=".asmx" type="System.Web.Compilation.WebServiceBuildProvider" />
                <add extension=".ashx" type="System.Web.Compilation.WebHandlerBuildProvider" />
                <add extension=".soap" type="System.Web.Compilation.WebServiceBuildProvider" />
                <add extension=".resx" type="System.Web.Compilation.ResXBuildProvider" />
                <add extension=".resources" type="System.Web.Compilation.ResourcesBuildProvider" />
                <add extension=".wsdl" type="System.Web.Compilation.WsdlBuildProvider" />
                <add extension=".xsd" type="System.Web.Compilation.XsdBuildProvider" />
                <add extension=".js" type="System.Web.Compilation.ForceCopyBuildProvider" />
                <add extension=".lic" type="System.Web.Compilation.IgnoreFileBuildProvider" />
                <add extension=".licx" type="System.Web.Compilation.IgnoreFileBuildProvider" />
                <add extension=".exclude" type="System.Web.Compilation.IgnoreFileBuildProvider" />
                <add extension=".refresh" type="System.Web.Compilation.IgnoreFileBuildProvider" />
                <add extension=".edmx" type="System.Data.Entity.Design.AspNet.EntityDesignerBuildProvider" />
                <add extension=".xoml" type="System.ServiceModel.Activation.WorkflowServiceBuildProvider, System.WorkflowServices, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"/>
                <add extension=".svc" type="System.ServiceModel.Activation.ServiceBuildProvider, System.ServiceModel.Activation, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" />
                <add extension=".xamlx" type="System.Xaml.Hosting.XamlBuildProvider, System.Xaml.Hosting, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" />
            </buildProviders>
            <expressionBuilders>
                <add expressionPrefix="Resources" type="System.Web.Compilation.ResourceExpressionBuilder" />
                <add expressionPrefix="ConnectionStrings" type="System.Web.Compilation.ConnectionStringsExpressionBuilder" />
                <add expressionPrefix="AppSettings" type="System.Web.Compilation.AppSettingsExpressionBuilder" />
                <add expressionPrefix="RouteUrl" type="System.Web.Compilation.RouteUrlExpressionBuilder"/>
                <add expressionPrefix="RouteValue" type="System.Web.Compilation.RouteValueExpressionBuilder"/>
            </expressionBuilders>
            <folderLevelBuildProviders>
                <add name="DataServiceBuildProvider" type="System.Data.Services.BuildProvider.DataServiceBuildProvider, System.Data.Services.Design, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"/>
            </folderLevelBuildProviders>
        </compilation>
        <healthMonitoring>
            <bufferModes>
                <add name="Critical Notification" maxBufferSize="100" maxFlushSize="20"
                    urgentFlushThreshold="1" regularFlushInterval="Infinite" urgentFlushInterval="00:01:00"
                    maxBufferThreads="1" />
                <add name="Notification" maxBufferSize="300" maxFlushSize="20"
                <add name="Analysis" maxBufferSize="1000" maxFlushSize="100"
                    urgentFlushThreshold="100" regularFlushInterval="00:05:00"
                    urgentFlushInterval="00:01:00" maxBufferThreads="1" />
                <add name="Logging" maxBufferSize="1000" maxFlushSize="200" urgentFlushThreshold="800"
                    regularFlushInterval="00:30:00" urgentFlushInterval="00:05:00"
            </bufferModes>
            <providers>
                <add name="EventLogProvider" type="System.Web.Management.EventLogWebEventProvider,System.Web,Version=4.0.0.0,Culture=neutral,PublicKeyToken=b03f5f7f11d50a3a" />
                <add connectionStringName="LocalSqlServer" maxEventDetailsLength="1073741823"
                    buffer="false" bufferMode="Notification" name="SqlWebEventProvider"
                    type="System.Web.Management.SqlWebEventProvider,System.Web,Version=4.0.0.0,Culture=neutral,PublicKeyToken=b03f5f7f11d50a3a" />
                <add name="WmiWebEventProvider" type="System.Web.Management.WmiWebEventProvider,System.Web,Version=4.0.0.0,Culture=neutral,PublicKeyToken=b03f5f7f11d50a3a" />
            </providers>
            <profiles>
                <add name="Default" minInstances="1" maxLimit="Infinite" minInterval="00:01:00"
                    custom="" />
                <add name="Critical" minInstances="1" maxLimit="Infinite" minInterval="00:00:00"
                    custom="" />
            </profiles>
            <rules>
                <add name="All Errors Default" eventName="All Errors" provider="EventLogProvider"
                    profile="Default" minInstances="1" maxLimit="Infinite" minInterval="00:01:00"
                    custom="" />
                <add name="Failure Audits Default" eventName="Failure Audits"
                    provider="EventLogProvider" profile="Default" minInstances="1"
                    maxLimit="Infinite" minInterval="00:01:00" custom="" />
            </rules>
            <eventMappings>
                <add name="All Events" type="System.Web.Management.WebBaseEvent,System.Web,Version=4.0.0.0,Culture=neutral,PublicKeyToken=b03f5f7f11d50a3a"
                    startEventCode="0" endEventCode="2147483647" />
                <add name="Heartbeats" type="System.Web.Management.WebHeartbeatEvent,System.Web,Version=4.0.0.0,Culture=neutral,PublicKeyToken=b03f5f7f11d50a3a"
                <add name="Application Lifetime Events" type="System.Web.Management.WebApplicationLifetimeEvent,System.Web,Version=4.0.0.0,Culture=neutral,PublicKeyToken=b03f5f7f11d50a3a"
                <add name="Request Processing Events" type="System.Web.Management.WebRequestEvent,System.Web,Version=4.0.0.0,Culture=neutral,PublicKeyToken=b03f5f7f11d50a3a"
                <add name="All Errors" type="System.Web.Management.WebBaseErrorEvent,System.Web,Version=4.0.0.0,Culture=neutral,PublicKeyToken=b03f5f7f11d50a3a"
                <add name="Infrastructure Errors" type="System.Web.Management.WebErrorEvent,System.Web,Version=4.0.0.0,Culture=neutral,PublicKeyToken=b03f5f7f11d50a3a"
                <add name="Request Processing Errors" type="System.Web.Management.WebRequestErrorEvent,System.Web,Version=4.0.0.0,Culture=neutral,PublicKeyToken=b03f5f7f11d50a3a"
                <add name="All Audits" type="System.Web.Management.WebAuditEvent,System.Web,Version=4.0.0.0,Culture=neutral,PublicKeyToken=b03f5f7f11d50a3a"
                <add name="Failure Audits" type="System.Web.Management.WebFailureAuditEvent,System.Web,Version=4.0.0.0,Culture=neutral,PublicKeyToken=b03f5f7f11d50a3a"
                <add name="Success Audits" type="System.Web.Management.WebSuccessAuditEvent,System.Web,Version=4.0.0.0,Culture=neutral,PublicKeyToken=b03f5f7f11d50a3a"
            </eventMappings>
        </healthMonitoring>
        <httpHandlers>
            <add path="eurl.axd" verb="*" type="System.Web.HttpNotFoundHandler" validate="True" />
            <add path="trace.axd" verb="*" type="System.Web.Handlers.TraceHandler" validate="True" />
            <add path="WebResource.axd" verb="GET" type="System.Web.Handlers.AssemblyResourceLoader" validate="True" />
            <add verb="*" path="*_AppService.axd" type="System.Web.Script.Services.ScriptHandlerFactory, System.Web.Extensions, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" validate="False" />
            <add verb="GET,HEAD" path="ScriptResource.axd" type="System.Web.Handlers.ScriptResourceHandler, System.Web.Extensions, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" validate="False"/>
            <add path="*.axd" verb="*" type="System.Web.HttpNotFoundHandler" validate="True" />
            <add path="*.aspx" verb="*" type="System.Web.UI.PageHandlerFactory" validate="True" />
            <add path="*.ashx" verb="*" type="System.Web.UI.SimpleHandlerFactory" validate="True" />
            <add path="*.asmx" verb="*" type="System.Web.Script.Services.ScriptHandlerFactory, System.Web.Extensions, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" validate="False" />
            <add path="*.rem" verb="*" type="System.Runtime.Remoting.Channels.Http.HttpRemotingHandlerFactory, System.Runtime.Remoting, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" validate="False" />
            <add path="*.soap" verb="*" type="System.Runtime.Remoting.Channels.Http.HttpRemotingHandlerFactory, System.Runtime.Remoting, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" validate="False" />
            <add path="*.asax" verb="*" type="System.Web.HttpForbiddenHandler" validate="True" />
            <add path="*.ascx" verb="*" type="System.Web.HttpForbiddenHandler" validate="True" />
            <add path="*.master" verb="*" type="System.Web.HttpForbiddenHandler" validate="True" />
            <add path="*.skin" verb="*" type="System.Web.HttpForbiddenHandler" validate="True" />
            <add path="*.browser" verb="*" type="System.Web.HttpForbiddenHandler" validate="True" />
            <add path="*.sitemap" verb="*" type="System.Web.HttpForbiddenHandler" validate="True" />
            <add path="*.dll.config" verb="GET,HEAD" type="System.Web.StaticFileHandler" validate="True" />
            <add path="*.exe.config" verb="GET,HEAD" type="System.Web.StaticFileHandler" validate="True" />
            <add path="*.config" verb="*" type="System.Web.HttpForbiddenHandler" validate="True" />
            <add path="*.cs" verb="*" type="System.Web.HttpForbiddenHandler" validate="True" />
            <add path="*.csproj" verb="*" type="System.Web.HttpForbiddenHandler" validate="True" />
            <add path="*.vb" verb="*" type="System.Web.HttpForbiddenHandler" validate="True" />
            <add path="*.vbproj" verb="*" type="System.Web.HttpForbiddenHandler" validate="True" />
            <add path="*.webinfo" verb="*" type="System.Web.HttpForbiddenHandler" validate="True" />
            <add path="*.licx" verb="*" type="System.Web.HttpForbiddenHandler" validate="True" />
            <add path="*.resx" verb="*" type="System.Web.HttpForbiddenHandler" validate="True" />
            <add path="*.resources" verb="*" type="System.Web.HttpForbiddenHandler" validate="True" />
            <add path="*.mdb" verb="*" type="System.Web.HttpForbiddenHandler" validate="True" />
            <add path="*.vjsproj" verb="*" type="System.Web.HttpForbiddenHandler" validate="True" />
            <add path="*.java" verb="*" type="System.Web.HttpForbiddenHandler" validate="True" />
            <add path="*.jsl" verb="*" type="System.Web.HttpForbiddenHandler" validate="True" />
            <add path="*.ldb" verb="*" type="System.Web.HttpForbiddenHandler"  validate="True" />
            <add path="*.ad" verb="*" type="System.Web.HttpForbiddenHandler" validate="True" />
            <add path="*.dd" verb="*" type="System.Web.HttpForbiddenHandler" validate="True" />
            <add path="*.ldd" verb="*" type="System.Web.HttpForbiddenHandler" validate="True" />
            <add path="*.sd" verb="*" type="System.Web.HttpForbiddenHandler" validate="True" />
            <add path="*.cd" verb="*" type="System.Web.HttpForbiddenHandler" validate="True" />
            <add path="*.adprototype" verb="*" type="System.Web.HttpForbiddenHandler" validate="True" />
            <add path="*.lddprototype" verb="*" type="System.Web.HttpForbiddenHandler" validate="True" />
            <add path="*.sdm" verb="*" type="System.Web.HttpForbiddenHandler" validate="True" />
            <add path="*.sdmDocument" verb="*" type="System.Web.HttpForbiddenHandler" validate="True" />
            <add path="*.mdf" verb="*" type="System.Web.HttpForbiddenHandler" validate="True" />
            <add path="*.ldf" verb="*" type="System.Web.HttpForbiddenHandler" validate="True" />
            <add path="*.exclude" verb="*" type="System.Web.HttpForbiddenHandler" validate="True" />
            <add path="*.refresh" verb="*" type="System.Web.HttpForbiddenHandler" validate="True" />
            <add path="*.svc" verb="*" type="System.ServiceModel.Activation.HttpHandler, System.ServiceModel.Activation, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" validate="False"/>
            <add path="*.rules" verb="*" type="System.Web.HttpForbiddenHandler" validate="True"/>
            <add path="*.xoml" verb="*" type="System.ServiceModel.Activation.HttpHandler, System.ServiceModel.Activation, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" validate="False"/>
            <add path="*.xamlx" verb="*" type="System.Xaml.Hosting.XamlHttpHandlerFactory, System.Xaml.Hosting, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" validate="False"/>
            <add path="*.aspq" verb="*" type="System.Web.HttpForbiddenHandler" validate="True"/>
            <add path="*.cshtm" verb="*" type="System.Web.HttpForbiddenHandler" validate="True"/>
            <add path="*.cshtml" verb="*" type="System.Web.HttpForbiddenHandler" validate="True"/>
            <add path="*.vbhtm" verb="*" type="System.Web.HttpForbiddenHandler" validate="True"/>
            <add path="*.vbhtml" verb="*" type="System.Web.HttpForbiddenHandler" validate="True"/>
            <add path="*" verb="GET,HEAD,POST" type="System.Web.DefaultHttpHandler" validate="True" />
            <add path="*" verb="*" type="System.Web.HttpMethodNotAllowedHandler" validate="True" />
        </httpHandlers>
        <httpModules>
            <add name="OutputCache" type="System.Web.Caching.OutputCacheModule" />
            <add name="Session" type="System.Web.SessionState.SessionStateModule" />
            <add name="WindowsAuthentication" type="System.Web.Security.WindowsAuthenticationModule" />
            <add name="FormsAuthentication" type="System.Web.Security.FormsAuthenticationModule" />
            <add name="PassportAuthentication" type="System.Web.Security.PassportAuthenticationModule" />
            <add name="RoleManager" type="System.Web.Security.RoleManagerModule" />
            <add name="UrlAuthorization" type="System.Web.Security.UrlAuthorizationModule" />
            <add name="FileAuthorization" type="System.Web.Security.FileAuthorizationModule" />
            <add name="AnonymousIdentification" type="System.Web.Security.AnonymousIdentificationModule" />
            <add name="Profile" type="System.Web.Profile.ProfileModule" />
            <add name="ErrorHandlerModule" type="System.Web.Mobile.ErrorHandlerModule, System.Web.Mobile, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
            <add name="ServiceModel" type="System.ServiceModel.Activation.HttpModule, System.ServiceModel.Activation, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" />
            <add name="UrlRoutingModule-4.0" type="System.Web.Routing.UrlRoutingModule" />
            <add name="ScriptModule-4.0" type="System.Web.Handlers.ScriptModule, System.Web.Extensions, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"/>
        </httpModules>
        <mobileControls sessionStateHistorySize="6" cookielessDataDictionaryType="System.Web.Mobile.CookielessData">
            <device name="XhtmlDeviceAdapters"
                    predicateClass="System.Web.UI.MobileControls.Adapters.XhtmlAdapters.XhtmlPageAdapter"
                    predicateMethod="DeviceQualifies"
                    pageAdapter="System.Web.UI.MobileControls.Adapters.XhtmlAdapters.XhtmlPageAdapter">
                <control name="System.Web.UI.MobileControls.Panel"             adapter="System.Web.UI.MobileControls.Adapters.XhtmlAdapters.XhtmlPanelAdapter" />
                <control name="System.Web.UI.MobileControls.Form"              adapter="System.Web.UI.MobileControls.Adapters.XhtmlAdapters.XhtmlFormAdapter" />
                <control name="System.Web.UI.MobileControls.TextBox"           adapter="System.Web.UI.MobileControls.Adapters.XhtmlAdapters.XhtmlTextBoxAdapter" />
                <control name="System.Web.UI.MobileControls.Label"             adapter="System.Web.UI.MobileControls.Adapters.XhtmlAdapters.XhtmlLabelAdapter" />
                <control name="System.Web.UI.MobileControls.LiteralText"       adapter="System.Web.UI.MobileControls.Adapters.XhtmlAdapters.XhtmlLiteralTextAdapter" />
                <control name="System.Web.UI.MobileControls.Link"              adapter="System.Web.UI.MobileControls.Adapters.XhtmlAdapters.XhtmlLinkAdapter" />
                <control name="System.Web.UI.MobileControls.Command"           adapter="System.Web.UI.MobileControls.Adapters.XhtmlAdapters.XhtmlCommandAdapter" />
                <control name="System.Web.UI.MobileControls.PhoneCall"         adapter="System.Web.UI.MobileControls.Adapters.XhtmlAdapters.XhtmlPhoneCallAdapter" />
                <control name="System.Web.UI.MobileControls.List"              adapter="System.Web.UI.MobileControls.Adapters.XhtmlAdapters.XhtmlListAdapter" />
                <control name="System.Web.UI.MobileControls.SelectionList"     adapter="System.Web.UI.MobileControls.Adapters.XhtmlAdapters.XhtmlSelectionListAdapter" />
                <control name="System.Web.UI.MobileControls.ObjectList"        adapter="System.Web.UI.MobileControls.Adapters.XhtmlAdapters.XhtmlObjectListAdapter" />
                <control name="System.Web.UI.MobileControls.Image"             adapter="System.Web.UI.MobileControls.Adapters.XhtmlAdapters.XhtmlImageAdapter" />
                <control name="System.Web.UI.MobileControls.ValidationSummary" adapter="System.Web.UI.MobileControls.Adapters.XhtmlAdapters.XhtmlValidationSummaryAdapter" />
                <control name="System.Web.UI.MobileControls.Calendar"          adapter="System.Web.UI.MobileControls.Adapters.XhtmlAdapters.XhtmlCalendarAdapter" />
                <control name="System.Web.UI.MobileControls.TextView"          adapter="System.Web.UI.MobileControls.Adapters.XhtmlAdapters.XhtmlTextViewAdapter" />
                <control name="System.Web.UI.MobileControls.MobileControl"     adapter="System.Web.UI.MobileControls.Adapters.XhtmlAdapters.XhtmlControlAdapter" />
                <control name="System.Web.UI.MobileControls.BaseValidator"     adapter="System.Web.UI.MobileControls.Adapters.XhtmlAdapters.XhtmlValidatorAdapter" />
            </device>
            <device name="HtmlDeviceAdapters"
                    predicateClass="System.Web.UI.MobileControls.Adapters.HtmlPageAdapter"
                    pageAdapter="System.Web.UI.MobileControls.Adapters.HtmlPageAdapter">
                <control name="System.Web.UI.MobileControls.Panel"             adapter="System.Web.UI.MobileControls.Adapters.HtmlPanelAdapter" />
                <control name="System.Web.UI.MobileControls.Form"              adapter="System.Web.UI.MobileControls.Adapters.HtmlFormAdapter" />
                <control name="System.Web.UI.MobileControls.TextBox"           adapter="System.Web.UI.MobileControls.Adapters.HtmlTextBoxAdapter" />
                <control name="System.Web.UI.MobileControls.Label"             adapter="System.Web.UI.MobileControls.Adapters.HtmlLabelAdapter" />
                <control name="System.Web.UI.MobileControls.LiteralText"       adapter="System.Web.UI.MobileControls.Adapters.HtmlLiteralTextAdapter" />
                <control name="System.Web.UI.MobileControls.Link"              adapter="System.Web.UI.MobileControls.Adapters.HtmlLinkAdapter" />
                <control name="System.Web.UI.MobileControls.Command"           adapter="System.Web.UI.MobileControls.Adapters.HtmlCommandAdapter" />
                <control name="System.Web.UI.MobileControls.PhoneCall"         adapter="System.Web.UI.MobileControls.Adapters.HtmlPhoneCallAdapter" />
                <control name="System.Web.UI.MobileControls.List"              adapter="System.Web.UI.MobileControls.Adapters.HtmlListAdapter" />
                <control name="System.Web.UI.MobileControls.SelectionList"     adapter="System.Web.UI.MobileControls.Adapters.HtmlSelectionListAdapter" />
                <control name="System.Web.UI.MobileControls.ObjectList"        adapter="System.Web.UI.MobileControls.Adapters.HtmlObjectListAdapter" />
                <control name="System.Web.UI.MobileControls.Image"             adapter="System.Web.UI.MobileControls.Adapters.HtmlImageAdapter" />
                <control name="System.Web.UI.MobileControls.BaseValidator"     adapter="System.Web.UI.MobileControls.Adapters.HtmlValidatorAdapter" />
                <control name="System.Web.UI.MobileControls.ValidationSummary" adapter="System.Web.UI.MobileControls.Adapters.HtmlValidationSummaryAdapter" />
                <control name="System.Web.UI.MobileControls.Calendar"          adapter="System.Web.UI.MobileControls.Adapters.HtmlCalendarAdapter" />
                <control name="System.Web.UI.MobileControls.TextView"          adapter="System.Web.UI.MobileControls.Adapters.HtmlTextViewAdapter" />
                <control name="System.Web.UI.MobileControls.MobileControl"     adapter="System.Web.UI.MobileControls.Adapters.HtmlControlAdapter" />
            </device>
            <device name="UpWmlDeviceAdapters"
                    inheritsFrom="WmlDeviceAdapters"
                    predicateClass="System.Web.UI.MobileControls.Adapters.UpWmlPageAdapter"
                    pageAdapter="System.Web.UI.MobileControls.Adapters.UpWmlPageAdapter">
            </device>
            <device name="WmlDeviceAdapters"
                    predicateClass="System.Web.UI.MobileControls.Adapters.WmlPageAdapter"
                    pageAdapter="System.Web.UI.MobileControls.Adapters.WmlPageAdapter">
                <control name="System.Web.UI.MobileControls.Panel"             adapter="System.Web.UI.MobileControls.Adapters.WmlPanelAdapter" />
                <control name="System.Web.UI.MobileControls.Form"              adapter="System.Web.UI.MobileControls.Adapters.WmlFormAdapter" />
                <control name="System.Web.UI.MobileControls.TextBox"           adapter="System.Web.UI.MobileControls.Adapters.WmlTextBoxAdapter" />
                <control name="System.Web.UI.MobileControls.Label"             adapter="System.Web.UI.MobileControls.Adapters.WmlLabelAdapter" />
                <control name="System.Web.UI.MobileControls.LiteralText"       adapter="System.Web.UI.MobileControls.Adapters.WmlLiteralTextAdapter" />
                <control name="System.Web.UI.MobileControls.Link"              adapter="System.Web.UI.MobileControls.Adapters.WmlLinkAdapter" />
                <control name="System.Web.UI.MobileControls.Command"           adapter="System.Web.UI.MobileControls.Adapters.WmlCommandAdapter" />
                <control name="System.Web.UI.MobileControls.PhoneCall"         adapter="System.Web.UI.MobileControls.Adapters.WmlPhoneCallAdapter" />
                <control name="System.Web.UI.MobileControls.List"              adapter="System.Web.UI.MobileControls.Adapters.WmlListAdapter" />
                <control name="System.Web.UI.MobileControls.SelectionList"     adapter="System.Web.UI.MobileControls.Adapters.WmlSelectionListAdapter" />
                <control name="System.Web.UI.MobileControls.ObjectList"        adapter="System.Web.UI.MobileControls.Adapters.WmlObjectListAdapter" />
                <control name="System.Web.UI.MobileControls.Image"             adapter="System.Web.UI.MobileControls.Adapters.WmlImageAdapter" />
                <control name="System.Web.UI.MobileControls.BaseValidator"     adapter="System.Web.UI.MobileControls.Adapters.WmlValidatorAdapter" />
                <control name="System.Web.UI.MobileControls.ValidationSummary" adapter="System.Web.UI.MobileControls.Adapters.WmlValidationSummaryAdapter" />
                <control name="System.Web.UI.MobileControls.Calendar"          adapter="System.Web.UI.MobileControls.Adapters.WmlCalendarAdapter" />
                <control name="System.Web.UI.MobileControls.TextView"          adapter="System.Web.UI.MobileControls.Adapters.WmlTextViewAdapter" />
                <control name="System.Web.UI.MobileControls.MobileControl"     adapter="System.Web.UI.MobileControls.Adapters.WmlControlAdapter" />
            </device>
            <device name="ChtmlDeviceAdapters"
                    inheritsFrom="HtmlDeviceAdapters"
                    predicateClass="System.Web.UI.MobileControls.Adapters.ChtmlPageAdapter"
                    pageAdapter="System.Web.UI.MobileControls.Adapters.ChtmlPageAdapter">
                <control name="System.Web.UI.MobileControls.Form"              adapter="System.Web.UI.MobileControls.Adapters.ChtmlFormAdapter" />
                <control name="System.Web.UI.MobileControls.Calendar"          adapter="System.Web.UI.MobileControls.Adapters.ChtmlCalendarAdapter" />
                <control name="System.Web.UI.MobileControls.Image"             adapter="System.Web.UI.MobileControls.Adapters.ChtmlImageAdapter" />
                <control name="System.Web.UI.MobileControls.TextBox"           adapter="System.Web.UI.MobileControls.Adapters.ChtmlTextBoxAdapter" />
                <control name="System.Web.UI.MobileControls.SelectionList"     adapter="System.Web.UI.MobileControls.Adapters.ChtmlSelectionListAdapter" />
                <control name="System.Web.UI.MobileControls.Command"           adapter="System.Web.UI.MobileControls.Adapters.ChtmlCommandAdapter" />
                <control name="System.Web.UI.MobileControls.PhoneCall"         adapter="System.Web.UI.MobileControls.Adapters.ChtmlPhoneCallAdapter" />
                <control name="System.Web.UI.MobileControls.Link"              adapter="System.Web.UI.MobileControls.Adapters.ChtmlLinkAdapter" />
            </device>
        </mobileControls>
        <pages>
            <namespaces>
                <add namespace="System" />
                <add namespace="System.Collections" />
                <add namespace="System.Collections.Generic" />
                <add namespace="System.Collections.Specialized" />
                <add namespace="System.ComponentModel.DataAnnotations" />
                <add namespace="System.Configuration" />
                <add namespace="System.Linq" />
                <add namespace="System.Text" />
                <add namespace="System.Text.RegularExpressions" />
                <add namespace="System.Web" />
                <add namespace="System.Web.Caching" />
                <add namespace="System.Web.DynamicData" />
                <add namespace="System.Web.SessionState" />
                <add namespace="System.Web.Security" />
                <add namespace="System.Web.Profile" />
                <add namespace="System.Web.UI" />
                <add namespace="System.Web.UI.WebControls" />
                <add namespace="System.Web.UI.WebControls.WebParts" />
                <add namespace="System.Web.UI.HtmlControls" />
                <add namespace="System.Xml.Linq" />
            </namespaces>
            <controls>
                <add tagPrefix="asp" namespace="System.Web.UI.WebControls.WebParts" assembly="System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
                <add tagPrefix="asp" namespace="System.Web.UI" assembly="System.Web.Extensions, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"/>
                <add tagPrefix="asp" namespace="System.Web.UI.WebControls" assembly="System.Web.Extensions, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"/>
                <add tagPrefix="asp" namespace="System.Web.UI.WebControls.Expressions" assembly="System.Web.Extensions, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"/>
                <add tagPrefix="asp" namespace="System.Web.DynamicData" assembly="System.Web.DynamicData, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"/>
                <add tagPrefix="asp" namespace="System.Web.UI.WebControls" assembly="System.Web.Entity, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
            </controls>
        </pages>
        <protocols>
            <add name="net.tcp" processHandlerType="System.ServiceModel.WasHosting.TcpProcessProtocolHandler, System.ServiceModel.WasHosting, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"
                appDomainHandlerType="System.ServiceModel.WasHosting.TcpAppDomainProtocolHandler, System.ServiceModel.WasHosting, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"
                validate="false" />
            <add name="net.pipe" processHandlerType="System.ServiceModel.WasHosting.NamedPipeProcessProtocolHandler, System.ServiceModel.WasHosting, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"
                appDomainHandlerType="System.ServiceModel.WasHosting.NamedPipeAppDomainProtocolHandler, System.ServiceModel.WasHosting, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"
                validate="false" />
            <add name="net.msmq" processHandlerType="System.ServiceModel.WasHosting.MsmqProcessProtocolHandler, System.ServiceModel.WasHosting, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"
                appDomainHandlerType="System.ServiceModel.WasHosting.MsmqAppDomainProtocolHandler, System.ServiceModel.WasHosting, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"
                validate="false" />
            <add name="msmq.formatname" processHandlerType="System.ServiceModel.WasHosting.MsmqIntegrationProcessProtocolHandler, System.ServiceModel.WasHosting, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"
                appDomainHandlerType="System.ServiceModel.WasHosting.MsmqIntegrationAppDomainProtocolHandler, System.ServiceModel.WasHosting, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"
                validate="false" />
        </protocols>
        <siteMap>
            <providers>
                <add siteMapFile="web.sitemap" name="AspNetXmlSiteMapProvider"
                    type="System.Web.XmlSiteMapProvider, System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
            </providers>
        </siteMap>
        <urlMappings enabled="true" />
        <webControls clientScriptsLocation="/aspnet_client/{0}/{1}/" />
        <webParts>
            <personalization>
                <providers>
                        name="AspNetSqlPersonalizationProvider" type="System.Web.UI.WebControls.WebParts.SqlPersonalizationProvider, System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
                </providers>
                <authorization>
                    <deny users="*" verbs="enterSharedScope" />
                    <allow users="*" verbs="modifyState" />
                </authorization>
            </personalization>
            <transformers>
                <add name="RowToFieldTransformer" type="System.Web.UI.WebControls.WebParts.RowToFieldTransformer" />
                <add name="RowToParametersTransformer" type="System.Web.UI.WebControls.WebParts.RowToParametersTransformer" />
            </transformers>
        </webParts>
    </system.web>
    <system.serviceModel>
        <serviceHostingEnvironment>
            <add name="net.tcp" transportConfigurationType="System.ServiceModel.Activation.TcpHostedTransportConfiguration, System.ServiceModel.Activation, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" />
            <add name="net.pipe" transportConfigurationType="System.ServiceModel.Activation.NamedPipeHostedTransportConfiguration, System.ServiceModel.Activation, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" />
            <add name="net.msmq" transportConfigurationType="System.ServiceModel.Activation.MsmqHostedTransportConfiguration, System.ServiceModel.Activation, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" />
            <add name="msmq.formatname" transportConfigurationType="System.ServiceModel.Activation.MsmqIntegrationHostedTransportConfiguration, System.ServiceModel.Activation, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" />
        </serviceHostingEnvironment>
    </system.serviceModel>
    <system.xaml.hosting>
        <httpHandlers>
          <add xamlRootElementType="System.ServiceModel.Activities.WorkflowService, System.ServiceModel.Activities, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" httpHandlerType="System.ServiceModel.Activities.Activation.ServiceModelActivitiesActivationHandlerAsync, System.ServiceModel.Activation, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"/>
          <add xamlRootElementType="System.Activities.Activity, System.Activities, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" httpHandlerType="System.ServiceModel.Activities.Activation.ServiceModelActivitiesActivationHandlerAsync, System.ServiceModel.Activation, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"/>
        </httpHandlers>
    </system.xaml.hosting>
</configuration>
_______________________
web_mediumtrust.config on 2003:
<configuration>
    <mscorlib>
        <security>
            <policy>
                <PolicyLevel version="1">
                    <SecurityClasses>
                        <SecurityClass Name="AllMembershipCondition" Description="System.Security.Policy.AllMembershipCondition, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"/>
                        <SecurityClass Name="AspNetHostingPermission" Description="System.Web.AspNetHostingPermission, System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"/>
                        <SecurityClass Name="DnsPermission" Description="System.Net.DnsPermission, System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"/>
                        <SecurityClass Name="EnvironmentPermission" Description="System.Security.Permissions.EnvironmentPermission, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"/>
                        <SecurityClass Name="FileIOPermission" Description="System.Security.Permissions.FileIOPermission, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"/>
                        <SecurityClass Name="FirstMatchCodeGroup" Description="System.Security.Policy.FirstMatchCodeGroup, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"/>
                        <SecurityClass Name="IsolatedStorageFilePermission" Description="System.Security.Permissions.IsolatedStorageFilePermission, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"/>
                        <SecurityClass Name="NamedPermissionSet" Description="System.Security.NamedPermissionSet"/>
                        <SecurityClass Name="PrintingPermission" Description="System.Drawing.Printing.PrintingPermission, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a"/>
                        <SecurityClass Name="SecurityPermission" Description="System.Security.Permissions.SecurityPermission, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"/>
                        <SecurityClass Name="SmtpPermission" Description="System.Net.Mail.SmtpPermission, System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"/>
                        <SecurityClass Name="SqlClientPermission" Description="System.Data.SqlClient.SqlClientPermission, System.Data, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"/>
                        <SecurityClass Name="StrongNameMembershipCondition" Description="System.Security.Policy.StrongNameMembershipCondition, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"/>
                        <SecurityClass Name="TypeDescriptorPermission" Description="System.Security.Permissions.TypeDescriptorPermission, System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"/>
                        <SecurityClass Name="UIPermission" Description="System.Security.Permissions.UIPermission, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"/>
                        <SecurityClass Name="UnionCodeGroup" Description="System.Security.Policy.UnionCodeGroup, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"/>
                        <SecurityClass Name="UrlMembershipCondition" Description="System.Security.Policy.UrlMembershipCondition, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"/>
                        <SecurityClass Name="WebPermission" Description="System.Net.WebPermission, System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"/>
                        <SecurityClass Name="ZoneMembershipCondition" Description="System.Security.Policy.ZoneMembershipCondition, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"/>
                        <SecurityClass Name="ReflectionPermission" Description="System.Security.Permissions.ReflectionPermission, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"/>
			<SecurityClass Name="OleDbPermission" Description="System.Data.OleDb.OleDbPermission, System.Data, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
			<SecurityClass Name="OdbcPermission" Description="System.Data.Odbc.OdbcPermission, System.Data, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
		    </SecurityClasses>
                    <NamedPermissionSets>
                        <PermissionSet
                                class="NamedPermissionSet"
                                version="1"
                                Unrestricted="true"
                                Name="FullTrust"
                                Description="Allows full access to all resources"
                        <PermissionSet
                                version="1"
                                Name="Nothing"
                                Description="Denies all resources, including the right to execute"
                        <PermissionSet
                                version="1"
                                Name="ASP.Net">
                            <IPermission
                                    class="AspNetHostingPermission"
                                    version="1"
                                    Level="Medium"
                            <IPermission
                                    class="DnsPermission"
                                    version="1"
                                    Unrestricted="true"
                            <IPermission
                                    class="EnvironmentPermission"
                                    version="1"
                                    Read="TEMP;TMP;USERNAME;OS;COMPUTERNAME"
                            <IPermission
                                    class="FileIOPermission"
                                    version="1"
                                    Read="$AppDir$"
                                    Write="$AppDir$"
                                    Append="$AppDir$"
                                    PathDiscovery="$AppDir$"
                            <IPermission
                                    class="IsolatedStorageFilePermission"
                                    version="1"
                                    Allowed="AssemblyIsolationByUser"
                                    UserQuota="9223372036854775807"
			    <IPermission
				    class="OleDbPermission"
				    version="1"
				    Unrestricted="true"
			    <IPermission
				    class="OdbcPermission"
				    version="1"
				    Unrestricted="true"
                            <IPermission
                                    class="PrintingPermission"
                                    version="1"
                                    Level="DefaultPrinting"
                            <IPermission
                                    class="SecurityPermission"
                                    version="1"
                                    Flags="Execution, ControlThread, ControlPrincipal, RemotingConfiguration"
                            <IPermission
                                    class="SmtpPermission"
                                    version="1"
                                    Access="ConnectToUnrestrictedPort"
                            <IPermission
                                    class="SqlClientPermission"
                                    version="1"
                                    Unrestricted="true"
                            <IPermission
                                    class="TypeDescriptorPermission"
                                    version="1"
                                    Unrestricted="true"
                            <IPermission
                                    class="WebPermission"
                                    version="1"
                                    Unrestricted="true"
                            <IPermission
                                    class="ReflectionPermission"
                                    version="1"
                                    Flags="ReflectionEmit, RestrictedMemberAccess"/>
                        </PermissionSet>
                    </NamedPermissionSets>
                    <CodeGroup
                            class="FirstMatchCodeGroup"
                            version="1"
                            PermissionSetName="Nothing">
                        <IMembershipCondition
                                class="AllMembershipCondition"
                                version="1"
                        <CodeGroup
                                class="UnionCodeGroup"
                                version="1"
                                PermissionSetName="ASP.Net">
                                    class="UrlMembershipCondition"
                                    version="1"
                                    Url="$AppDirUrl$/*"
                        </CodeGroup>
                        <CodeGroup
                                version="1"
                                    version="1"
                                    Url="$CodeGen$/*"
                        </CodeGroup>
                    </CodeGroup>
                </PolicyLevel>
            </policy>
        </security>
    </mscorlib>
</configuration>
On Windows 2008 we are allowing high Trust as follows:
The trust config:
[code]
[/code]
the web.config
<configuration>
        <system.web>
            <securityPolicy>
            </securityPolicy>
            <trust level="High" originUrl="" />
                <add
                    version="10.0.0.0"
                <add
                    version="10.0.0.0"
                <add
                    version="1.0.0.0"
                <add
                    version="4.0.0.0"
        </system.web>
    </location>
    <system.codedom>
        <compilers>
            </compiler>
            </compiler>
        </compilers>
    </system.codedom>
    <system.net>
        <defaultProxy>
        </defaultProxy>
    </system.net>
    <system.web>
        <authorization>
            <allow users="*" />
        </authorization>
        </browserCaps>
        <clientTarget>
        </clientTarget>
        <compilation>
            <assemblies>
                <add assembly="System.ServiceModel.Activation, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" />
                <add assembly="System.ServiceModel.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" />
                <add assembly="System.Activities, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" />
                <add assembly="System.ServiceModel.Activities, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" />
                <add assembly="System.WorkflowServices, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" />
                <add assembly="System.ComponentModel.DataAnnotations, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" />
                <add assembly="System.Web.DynamicData, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" />
                <add assembly="System.Web.WebPages.Deployment, Version=1.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" />
            </assemblies>
            <buildProviders>
                <add extension=".xoml" type="System.ServiceModel.Activation.WorkflowServiceBuildProvider, System.WorkflowServices, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" />
            </buildProviders>
                <add name="DataServiceBuildProvider" type="System.Data.Services.BuildProvider.DataServiceBuildProvider, System.Data.Services.Design, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
                <add expressionPrefix="RouteUrl" type="System.Web.Compilation.RouteUrlExpressionBuilder" />
                <add expressionPrefix="RouteValue" type="System.Web.Compilation.RouteValueExpressionBuilder" />
        </compilation>
        <healthMonitoring>
            <bufferModes>
            </bufferModes>
            <providers>
            </providers>
            <profiles>
                    custom="" />
                    custom="" />
            </profiles>
            <rules>
                    custom="" />
            </rules>
            <eventMappings>
            </eventMappings>
        </healthMonitoring>
        <httpHandlers>
        </httpHandlers>
        <httpModules>
        </httpModules>
            </device>
            </device>
            </device>
            </device>
            </device>
        </mobileControls>
        <pages>
            <namespaces>
            </namespaces>
            <controls>
            </controls>
        </pages>
        <protocols>
                validate="false" />
                validate="false" />
                validate="false" />
                validate="false" />
        </protocols>
        <siteMap>
            <providers>
            </providers>
        </siteMap>
        <webParts>
            <personalization>
                <providers>
                </providers>
                <authorization>
                </authorization>
            </personalization>
            <transformers>
            </transformers>
        </webParts>
    </system.web>
        <httpHandlers>
        </httpHandlers>
</configuration>
Hi Saviours,
i am new to Trust level config.i got one requirment by client to set custom Trust level . I want to set some custom level permissions. can anyone spare some time to explain me where i have to put the policyfile in application or server.
Also some basic knowledge about its usage..
