Connectivity
Ron
Perch
I was wondering if network speeds or connectivity would be affected once you have fully shifted to the PA datacenter? You are getting such brilliant speeds from Atlanta that it would be a pity if things slowed down.
We will have different ISPs but don't worry about the speeds. In fact I believe connectivity/speeds should be better in PA
