Web mail over https?
energed
Guppy
Hi, i just started to use your services. Do you have any options which could/would allow me to use webmail over https?
Sorry my bad english.
should be
am sure ive seen others say they've installed there own webmail clients
it'll prob be the best way to get to work with SSL aswell
if you have ssl on a domain its on the whiole domain ie anything within the site can be secured using https.
you can require to go thruogh SSL or only directly, ie when you set https
hope that helps
Emagine: yes that hepled. There was sone confusing times when shared and dedicated ip:s was pointing into wrong site =).
Thanks again for everyone.
Next question: Have anybody installed IMP webmail program by yourself? Did you install Horde first or not?
Thanks.
