C# (.NET) Problem...
DeepakG
Perch
Any .NET Programmers here?
I am trying to use the following C# code to emit some javascript code. It works fine at home, but doesn't emit the javascript when used on Jodohost.
Code:
using System;
using System.Collections;
using System.Collections.Specialized;
using System.ComponentModel;
using System.Web.UI;
using System.Web.UI.WebControls;
using System.Web.UI.HtmlControls;
public class TreeView : Table, INamingContainer
    The rest of the code was truncated.
		protected override void OnPreRender(EventArgs e)
			if (!Page.IsClientScriptBlockRegistered("ShowHideTable") && !Page.IsPostBack)
				Page.RegisterClientScriptBlock("ShowHideTable", ShowHideTableScript());
			base.OnPreRender (e);
		public static string ShowHideTableScript()
			const string script =
			@"<script language=""JavaScript"">
			   function ShowHideTable( targetId )
					if (document.getElementById){
						target = document.getElementById( targetId );
						if (target.style.display == ""none""){
							target.style.display = """";
						else {
							target.style.display = ""none"";
			</script>
			return script;
Note: This class implements a web control by inheriting from System.Web.Ui.WebControls.Table. There are NO syntax or runtime errors. The code simply does not output the Javascript on Jodohost, but works on my local web server.
