Enterprise Library
Daze
Perch
Are any of you using the Enterprise Library (Microsoft Patterns and Practices) in your Jodohost hosted site?
I'm using it for the data access layer in my new site, but I had problems getting it to work locally initially. I kept getting a "Requested Registry Access Error" error, which appears to be fairly common. It can be fixed by either changing a registry setting or installing some services (via a .bat file, which is what I did), but I can't perform these actions on the Jodohost server (and I wouldn't want to tbh).
Hopefully I'm worrying about nothing...
I have it installed locally,but I have never actually used it,but I also have the ASP.NET 2.0 version, do you have 1.1 or 2.0?
Hi Stephen. I'm using the 1.1 version (June 2005 release).
I'm going to upload a W.I.P. of my site tonight, to see if there are any problems.
Nope... Same problem on Jodohost:
SecurityException: Requested registry access is not allowed.
