Grrr... Win5 .Net problems?
Discussion in 'H-Sphere Shared Hosting' started by dannyc, Nov 20, 2004.
  1. dannyc
    dannyc Perch
    My .Net sites are giving me an error page (they were working last night). I can't tell what the actual error is because the server doesn't seem to be noticing my customErrors mode change (from RemoteOnly to Off) in web.config, and will only give me the "friendly" error message. Anyone else having problems?
  2. Yash
    Yash Bass
    Turn off and then on ASP.net.
    If that doesn't work, you need full asp.net permissions, submit a ticket and it would be done fast
  3. dannyc
    dannyc Perch
    To disable ASP.Net on this domain, I have to first disable MS SQL Manager. When I attempt to disable MS SQL Manager, it warns me that data will be lost; what data is it referring to? (This domain does use a MSSQL database.)
  4. Stephen
    Danny, I can check permissions, I do not recall that error, there have been a few in .net however.
    If you can ticket or PM the domain it would be helpful.
  5. Stephen
    Both domains are now working.
  6. yorri
    yorri Perch
    Just so you know for the future, it doens't affect any of your database or your files. I have been able to disable it and it didn't delete anything of mine. I think it just deletes the application files...which are not stored in my domain so I have no idea where it is or what it does specifically BUT I know it is safe to say ok to the delete.
  7. Stephen
    I thought this had already been resolved, files going over now.
  8. phr3232
    phr3232 Guest
    Thanks v. much - original post removed.
  9. AndyLL
    AndyLL Perch
    OK... I just realized .net is not working on my sites either. So to turn off/on asp.net it says I must disable Sql server manager.
    2 questions:
    1) where do I do that? I don't see that option.
    2) are we sure that turning off the sql server manager will not affect my database?
    Andy
  10. Deepak-JH
    Deepak-JH Oceanic Police
    Kindly open a ticket so that we can exactly look in to the matter or if you have already opened, please give us ticket no.
  11. AndyLL
    AndyLL Perch
    I just put in a ticket listing the domains:
    41365
    Andy
  12. Deepak-JH
    Permission issue with ASP.NET for your domains has been fixed and Your ticket has been replied, Please check it now.
Share This Page
Plesk Web Hosting
VPS Hosting
H-Sphere Web Hosting
Other Services
