V
vinu
Guest
I have a problem where MSSQL2000 on 2003 server is not communicating through
other clients, also it is not communicating between two 2003 servers.
Locally it is working. OBDC connections from client and another 2003 server
does not work. Basically it does not listen on 1433 port on the server where
database is there.
I have installed the service pack 3a, but no use.
You might have cracked the same issue, so pl. let me know what solution ???
database is there.
