thingwarbler
Perch
I'm hoping someone can offer some additional clarification: I generated a key request thru hsphere, sent the request along to my CA (IPSCA), and got a CR and a private key, as well as a temp. cert.
Now I have the "official" cert, and I assumed I could just go drop it off in hsphere under "Install Certificate based on previously generated Certificate request" -- but when I do that, I get error messages from browsers when I hit the secure site -- "Security Connection Failed" with (Error code: sec_error_unknown_issuer).
IPSCA talk about a bundle file with root CAs, but there's nowhere I can drop those off as far as I can tell, and the instructions to do so indicate that I should be dropping them in the root of the server -- not happening, is it now?
What do I do -- I really shouldn't need to get with support for this, it's by the book and should be doable thru hsphere, no?
