How do I connect with Frontpage?
No, enter in your FTP login details into FrontPage and get it to publish in the domain folder where you have enabled frontpage extensions
Thanks yash...I was just told that I have to use my domain name for the server name. It has been way too long since I have used frontpage extensions.
Anyway...I got it working....now I will test Interdev setting up a web application in a subfolder and see if it works for ASP.NEt... will keep you posted
Getting excited now :)
