Hi, I'm having huge trouble creating an MS SQL database (66.232.25.15)
I create a database login, then a database.
But can't create a db user.
When i connect with SQL Enterprise there is no database there - connection goes fine.
If I try and use web based SQL Manager I can't login with any username password combination; either FTP or the database login.
Please Help!!
Please Help!!
