joomla 1.0.12 problem
cdog
Perch
A customer has uninstalled joomfish multilingual transactions that enabled shoppers to change the sites language.
it looks as if joomfish is still installed and I can see his other custom modules related to joomfish in the admin area and it reports they are published.
He has stated that he uninstalled the multilingual plugin so therefore the language option selection is not showing.
joomfish version is 1.7
Hopefully someone can help me with the questions below
Can the multilingual plugin be installed seperately or would joomfish need to be reinstalled-- my initial suggestion was just to reinstall joomfish
I have next to no experience with joomla and am coming at this from a standing start
Thanks in advance
EDIT
Would anyone have the joomfish 1.7 installation package?
if I can get jfdatabase.systembot.php and xml file it may fix the issue. Its an older version and Ive had no luck finding it on the web
