PHP mail script for web15?
Discussion in 'Email Support' started by bro, May 13, 2011.
  1. bro
    bro Perch
    What mail components/scripts are available for use (and working) on web15?
    I don't use PHP a lot outside of CMSs, but last time I think I was able to use phpmailer, which appears not to be installed.
    (Anyone got a complete working mailform script using SMTP, by the way?)
  2. Stephen
    phpmailer is just a class, it can be loaded without issue.
  3. zaboss
    zaboss Perch
    I have a similar issue on web30. Have several blogs - simple wordpress installation, no customizations - and just realized that after the move I have no longer receive mail notification. I have tryed a SMTP plugin as per support sugestion, but that don't works either. Support ticket: RS #BIP-99179-771.
  4. abhishek
    abhishek Administrator Staff Member
    We have replied your ticket.We have tested wp-mail-smtp, it worked fine without any error.
  5. liming
    liming Perch
    @bro were you able to find a PHP mail script?
    I think I have the same problem as you. Basically I have a contact form using this simple command:
    Code:
    $sent = mail( "contact@example.com", "From: Contact Page", $message, "From: $name <$email>" );
    And I used to be able to get mail just fine but I just noticed that it now no longer works.
    Do you have any suggestions or maybe I should just submit a ticket...
  6. Stephen
    it is best to always use SMTP auth and mail against that with the smtp server.
  7. liming
    liming Perch
    ^ got it, I'll try that out.
    I'm not much of a php person so please forgive my I-don't-have-a-clueness :)
Share This Page
Plesk Web Hosting
VPS Hosting
H-Sphere Web Hosting
Other Services
