We shall be doing some Maintenance (few updates needed) on PSBM server and required reboot it.
We appreciate your patience and Co-operation in this regard.
That is actually resolved now, on its own, the updates applied were to fix some issues with the power panel application and it seems they had to reset the VM config files which took the IPs off for a moment.
