Some questions on Reselling
vrom
Guppy
Hi
I consider to make reselling of specially configured hosting for CMS TYPO3 (www.typo3.com)
http://typo3.org/download/system-requirements/
As I see in forum, TYPO3 works on your shared hosting plans.
Questions:
1) do you give IP in different C-class networks for DNS
(this is needed to host national domains - RU-domains for example)
2) Is it true that I can resell
- shared hosting accounts (which will have the same configuration as all shared hosting accounts on this server)
- VPS accounts, which can have different configuration
(use eAccelerator for PHP, different memory_limit in PHP)
3) What is configuratuion of shared hosting account:
- memory_limit in PHP (I need at least 16Mb)
- any PHP acceselerator
- GD
- ImageMagic
(can you give me link to phpinfo() results ?)
4) If I will sell VPS for TYPO3, can I do special reconfiguration of this VPS for TYPO3 (eAccelerator http://eaccelerator.net/HomeUk etc)
befor my client will get access to account?
5) Is it possible to host many domains on a shared or VPS account?
6) Is it possibe to resell shared accounts, that will be within VPS (like on VPS with CPanel)? I consider to make configuration for TYPO3 on one VPS with one example of core files eAcceselerator to reduce server load.
7) Anonymous Support Guide. I plan to use it. Is it possible to agree that special TYPO3-related questions will be forwarded to me?
8) Do you have German and Russian language in control panel?
9 ) Can you recommend how I can offer domain registration (reselling with any domain registartor, compatible with hosting panel ? )
10 ) I plan to use 2checkout.com for payments. Is it good idea?
11) Can I configure control panel to sell for example "1 hour ofTYPO3-consulting" for $25
(things wich is not hosting)?
12) Have you any resellers from Russia ( ;) yes or no will be good answer)
Thank you in advance.
Valery.
Hi Valery,
Following are the answers of your questions:
>> This may not be possible in general. But you can request support for this.
>> Yes it is the same.
>> VPS accounts are bare linux installs and you need to setup everything by yourself.
>> Required module is not enabled.
>>No. Only Zend optimizer. but that doesnt solves your purpose anyway.
- GD
>> Yes it is enabled in PHP.
- ImageMagic
>> This package is also installed.
4) If I will sell VPS for TYPO3, can I do special reconfiguration of this VPS for TYPO3 (eAccelerator http://eaccelerator.net/HomeUk etc) befor my client will get access to account?
>> You need to setup by yourself on VPS.
>> Yes. For a user account, as many as you have setup in your plans(as a reseller). In VPS you need to setup webserver and host as many domains as possible within the resource limits of your VPS account.
>> No. Again, since VPS is a plain linux install you need to setup your own control panel within that VPS account. You can as a reseller make VPS plans.
>> Guide is here: http://jodohost.com/anonsupport.asp
Since you will also have access to the Helpdesk, you can answer them on your own.
>> Yes, in your control panel you can set German or Russian for your use.
9 ) Can you recommend how I can offer domain registration (reselling with any domain registartor, compatible with hosting panel ?)
>> You can make a reseller account at www.domain.jodohost.com (it is free) and set your own price to resell the domains to your clients. But domain registration is not intergrated into our hosting control panel(Hsphere).
>>Yes, it is Good and also prevent fraud by Credit card etc.
11) Can I configure control panel to sell for example "1 hour ofTYPO3-consulting" for $25 (things wich is not hosting)?
>>No, Hsphere is a hosting automation solution and doesnt provides billing-only plans.
12) Have you any resellers from Russia ( yes or no will be good answer)
>> Yes, we have resellers from Russia too :)
Please feel free to contact us for further querries. You may write at sales @ jodohos.com (without space).
