upsizing advice MDB -> SQL
snooper
Perch
hi all.
when i develop an app which will use an SQL db - i usually
do the following:
1) design the tables/fields in Access
2) run the EM Import/export Wizard to upsize the strcuture and existing data
3) login thru the ASP.NET MSSQL Manager and fix all the Identity/Seed/Increment fields which dont seem to upsize properly from Access.
Is there an easier way to do this?
Thanks!
There is a free for personal use application called Aqua Data Studio that I recnetly learned about(here), it is really great.
Then there is SQL Server Management Studio 2005 Express Edition which MS has available free for download.
