BluJag
Perch
Using PayPal IPNs
asp.net using VB
On your site you want to accept payment using PayPal (credit card or a PayPal account). The code below will be executed as soon as your customer has successfully paid. Whether your customer returns to your site or not doesn't matter. The <return> value in the html form below will take your customer to a thankyou.aspx page after he clicks the "Return to merchant" button on PayPal after he's paid.
This bit of html goes into your payment page eg payments.aspx. Here you would have a summary of what it is he's paying for etc.
The asp literals are set in the payments.aspx.vb page.
<form action="https://www.paypal.com/cgi-bin/webscr" method="post">
<input type="hidden" value="Message to my Website" name="cn">
<input id="first_name" type="hidden" value="<asp:Literal" name="first_name" runat="server">
<input id="last_name" type="hidden" value="<asp:Literal" name="last_name" runat="server">
<input id="address1" type="hidden" value="<asp:Literal" name="address1" runat="server">
<input id="address2" type="hidden" value="<asp:Literal" name="address2" runat="server">
<input id="city" type="hidden" value="<asp:Literal" name="city" runat="server">
<input id="state" type="hidden" value="<asp:Literal" name="state" runat="server">
<input id="zip" type="hidden" value="<asp:Literal" name="zip" runat="server">
<input id="email" type="hidden" value="<asp:Literal" name="email" runat="server">
<input id="night_phone_a" type="hidden" value="<asp:Literal" name="night_phone_a" runat="server">
<input type="hidden" value="_xclick" name="cmd">
<input type="hidden" value="[email protected]" name="business">
<input type="hidden" value="Buying My Service" name="item_name">
<input id="amount" type="hidden" value="<asp:Literal" name="amount" runat="server">
<input type="hidden" value="PayPal" name="page_style">
<input type="hidden" value="1" name="no_shipping">
<input id="item_number" type="hidden" value="<asp:Literal" name="item_number" runat="server"> ////This would hold the member ID or customer ID etc
<input type="hidden" value="http://www.mywebsite.com/thankyou.aspx" name="return">
<input type="hidden" value="http://www.mywebsite.com/someotherpage.aspx" name="cancel_return">
<input type="hidden" value="1" name="no_note">
<input type="hidden" value="GBP" name="currency_code">
<input type="hidden" value="GB" name="lc">
<input id="notify_url" type="hidden" value="http://www.mywebsite.com/process_payment.aspx" name="notify_url">
<input name="submit" type="image" src="graphics/paynow.gif" alt="Make payments with PayPal - it's fast, free and secure!" align="middle" border="0">
</form>
The process_payment.aspx has just this
<%@ Page CodeBehind="process_payment.aspx.vb" Language="vb" AutoEventWireup="false" Inherits="mynamespace.process_payment" %>
It is not displayed to the customer at all but just runs as a result of the PayPal IPN process.
Below is the process_payment.aspx.vb page.
Imports System.Net
Imports System.IO
Public Class process_payment
Inherits System.Web.UI.Page
Private Sub Page_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
'Put user code to initialize the page here
'// Step 1a: Modify the POST string.
Dim formPostData As String = "cmd=_notify-validate"
Dim postValue As String
Dim postKey As String
Dim postByteArray As Byte()
Dim responseArray As Byte()
Dim PayPalResponse As String
Dim MemID As String = Request.Form("item_number") '//This comes from the <input id="item_number" type="hidden" value="<asp:Literal" name="item_number" runat="server"> line of html above which would have the customer ID or member ID etc.
For Each postKey In Request.Form
postValue = Encode(Request.Form(postKey))
formPostData += String.Format("&{0}={1}", postKey, postValue)
Next
'// Step 1b: POST the data back to PayPal.
Dim client As New System.Net.WebClient
client.Headers.Add("Content-Type", "application/x-www-form-urlencoded")
postByteArray = System.Text.Encoding.ASCII.GetBytes(formPostData)
responseArray = client.UploadData("https://www.paypal.com/cgi-bin/webscr", "POST", postByteArray)
PayPalResponse = System.Text.Encoding.ASCII.GetString(responseArray)
''// Step 1c: Process the response from PayPal.
Select Case PayPalResponse
Case "VERIFIED"
'// code here to update your database, send confirmatory email to customer and so on. You have the MemID value from above so you know which customer it is.
Case Else
'// Possible fraud. Log for investigation.
End Select
End Sub
Private Function Encode(ByVal OldValue as String) As String
' This helper method encodes a string correctly for an HTTP POST
Dim newValue As String
newValue = OldValue.Replace("\", "")
newValue = System.Web.HttpUtility.UrlEncode(newValue)
newValue = newValue.Replace("%2f", "/")
Return newValue
End Function
End Class
asp.net using VB
</form>
Imports System.Net
Imports System.IO
Next
Case "VERIFIED"
Case Else
End Select
End Sub
Return newValue
End Function
End Class
