404 and Under Construction Errors...
Me again :smiley:
Everything’s working great except now when you go to a newly regg’d domain ( http://www.666labs.com/ ) You get the Under Const. error. I then used the Web Manager tool to create a simple Hello Worl index.html file at root, and tried to point to that, and I’m getting a 404.
I read this thread ( http://support.jodohost.com/showthread.php?t=896 ) and he seemed to have the same problem, but was miraculously cured ?(
Any help is appreciated!
. psyance .
To use Shared SSL, you need to assign a dedicated IP. once you have done that, open a ticket and we’ll correct the issue
