I’m trying to do some simple php programming that requires me to use the curl library. I have not found a way to enable this on our server. Some people have said to add a custom php.ini file to my domain directory I want to use it on but I’m either using the wrong file or implementing it wrong… Any advice on how to enable usage of the curl library? It seems simple but I’m lost.
-Ray
