Add Dedicated IP
How do I add a dedicated IP?
I also want to add SSL Cert to my domain. I have already purchased an SSL Cert elsewhere, however will I need to purchase a new one since my SSL cert comes from godaddy which is included in the monthly hosting account?
We do not sell SSL, but you can certainly add a dedicated IP to make SSL, however you may have to regenerate your certificate at godaddy once you have the new CSR.
I purchased a separate SSL certificate. I do not want anything to do with godaddy =)
I need to generate a CSR, but I entered a support ticket so that I can add a dedicated IP to my account. Before I generate CSR I need dedicated ip to activate.
My support ticket # is JH #GIY-91070-608
oh ok, I understand you now.
You can purchase the SSL Cert anywhere else, we will have that dedicated IP to you shortly to get moving with it.
