anyone else having permission issues on mssql10?
i cant create tables, and now - i cant even see my previously imported ones.
help!
Use EMS SQL Manager, it has been this way from the start if you are using Studio Manager :slight_smile:
EMS SQL Manager Lite for SQL Server - MS SQL Sever management
yeah, i know - you guys ran a script so that i can run the database thru Studio Manager, and it works great for a number of other databases (even belonging to the same account) - but not this one.
while support was playing, my tables disappeared , and i cant even see them via Aqua data anymore.
database name: olami_main613
thanks!
it sounds like your user lost permissions to the DB, I will need a ticke to know the proper user.
Your issue is fixed now.
