I’m using an API that requires a dedicated ip. The reason is to safeguard abuse of the script by failing to execute any call outside of the domain/ip it resides on.
My account is hosted with a dedicated ip, a ping on my domain reflects the dedicated ip shown within my cp, but the API fails to execute.
Is the IP shown in my cp, and via ping, somehow masked? How do I determine my IP?
does it not mean that the IP you access the admin page is dedicated.
Like Cerberus helpdesk. You must put IP’s that are allowed to access the admin, into the config file. And so. if you dont have a dedicated IP from you ISP, then you have to keep updating your config.
Probably on the wrong track, but never mind!! Usually am!!
[QUOTE=bored_admin]
If I was hosting the script on my computer you would be correct, but the script is being hosted/executed from my web site hosted with JodoHost. Basically; End-user > Web Site > PHP Code > Remote API > Return results to end-user’s web browser.
Any who, it’s working now; and with no changes made to the script. It very well may have been updates I had made to my DNS which had not fully propogated. Not sure.
