application vars
hi
i used to have a SOOP portal running, and i just deleted the database.
i now have a WWF forum running, but it seems to be drawing info from the old SOOP applications vars.
how can i fix this, does anyeone know?
many thanks
Sn
really didn’t understand this ..
just that SOOP and WWF (seperately) use the same applications variables, so the one is drawing from the other, and not its own (cos they sare named the same!)
Submit a ticket asking one of the applications to be moved into high isolation
thanks :slight_smile:
